Xbr450 - AVS Forum | Home Theater Discussions And Reviews
Old 07-27-2011, 01:01 PM - Thread Starter
cwpl's Avatar
How SD look on a 36XBR450?
cwpl is offline
Old 07-27-2011, 01:34 PM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
It be looking like SD.
Ratman is offline
Old 07-27-2011, 02:33 PM - Thread Starter
cwpl's Avatar
Is it as good as say my 36XBR250? looking at specs seems to be a SD that can also display 1080. Or will 480 be a little grainy?
cwpl is offline
Old 07-27-2011, 03:16 PM
Ratman's Avatar
Liked: 1029
SD is always SD.
Yes, the TV can "accept" a 1080i signal, but you are at the mercy of the external device upconverting 480i to 1080i.
The TV will only display 480(i/p) or 1080i. And again, it depends on the input signal.
Just because it's HDTV capable, don't expect miracles with SD material(s). You can't make a silk purse from a sow's ear.
Ratman is offline
Old 07-27-2011, 11:49 PM - Thread Starter
cwpl's Avatar
I'm not concerned with trying to improve SD my 250 gets great picture just wonder if the 450 would be as good it with SD. I know some HD's are a little fuzzy with SD but like I said this seems to be a SD that just happens to be HD capable.
cwpl is offline
