Looking for assistance with KV-24FS100 WEGA - AVS Forum | Home Theater Discussions And Reviews
Old 08-07-2011, 06:11 PM - Thread Starter
RetroSG's Avatar
Hi -
I'm stumped from playing around in the Service Menu on how to adjust the angle/tilt issue i'm having with my WEGA.
Is there a command that would adjust the SKEW on just the left side - leaving the right as is?
I've played around with all of these:
HSIZ,HPOS,VSIZ,VPOS,VLIN,SCOR,VBOW,VANG,TRAP,PAMP,UPIN,LPIN
Note: This picture is with the Veritical position moved way down to show the angle of the disconnect (better frame of reference with black).
Thank you in advance for your expertise
RetroSG is offline
Old 08-08-2011, 11:38 AM
raouliii's Avatar
Is there a HTPZ setting? HTPZ is a horizontal keystone/trapezoid adjustment.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
Old 08-10-2011, 09:44 PM - Thread Starter
RetroSG's Avatar
Unfortunately no HTPZ - just TRAP, which wasn't effective.
Thanks for the response though.
RetroSG is offline
