Loewe Aconda and DVI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-25-2002, 03:05 PM - Thread Starter
ericlhyman's Avatar
Thanks for the information from Loewe in this and the other thread. I'm not sure if their representative is aware that Silicon Images stated that HDMI and DVI-CE will be backward compatible with DVI. A set with DVI will not be out in the cold on the copy protection issue; it just may not have the additional features of audio transmission through the same connection as the video or inter-connectivity of different components.
I think it would be a mistake for Loewe to ignore DVI. I, personally, would buy the Loewe set today if it had DVI. If it won't have it in the next few months, I will buy a competing product that has DVI. DVI or its more refined versions will be needed for time-shifting of HD programming. With my schedule, if I cannot time shift HD, I will not be able to watch much of it. HD PVRs will require one of these connections. Widescreen Review also reported that the next generation of the JVC HD-VCR will also have DVI. If I knew that Loewe would put DVI in before the end of the year, I would hold off on purchasing a set this summer or early fall when its competitors will have DVI-equipped sets available.
ericlhyman
ericlhyman is offline
Closed Thread Direct View (single tube) CRT Displays
