Deciding between three 36" tv's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-26-2002, 09:08 PM - Thread Starter
CyC
CyC's Avatar
Sony KV-36HS20
Toshiba KV-36HS20
Panasonic CT-36HX41
similiar in prices and features... any opinions...? im leanin toward Sony with panny on close 2nd...
CyC is offline
post #2 of 5 Old 04-26-2002, 11:12 PM
Ratters's Avatar
Personally I would go with the Sony. I bought a 34" Tosh. and the picture is fine but the build quality is much cheaper than the Sony.
But, my local Costco has the 36" Toshibia for $1399 right now. Not bad.
Ratters is offline
post #3 of 5 Old 04-27-2002, 08:45 AM
Matt_Stevens's Avatar
Liked: 48
BEWARE the uneven brightness inherent in the Sony KV line. Once you notice it, you will hate it. It cannot not be seen. :( The XBR line does not suffer from this nearly as much and can only be seen if you are really looking for it over a dark image.
Vimeo is the home of the Super8 Shooter...
http://vimeo.com/super8shooter
Matt_Stevens is offline
post #4 of 5 Old 04-27-2002, 05:06 PM
IUnknown's Avatar
Look at the physical dimensions. The Panny is very small and fits in my cabinet. Sometimes these small things make a difference if all else is equal.
IUnknown is offline
post #5 of 5 Old 04-27-2002, 10:47 PM
Waters_10's Avatar
I'm also looking for a 36" TV. And I am considering the JVC 36P902. It's the only set with DVI/HDCP in the market at the moment.
It's quite hard to find information on this set, but you can find some information on hdtvoice forum. There's a guy that has this set and post a lot of good information. According to him, this set has better picture than the Sony, Toshiba and Panny.
I can't say for myself, cause I couldn't find it in any local store. I'll try to do see it and if it's as good as the Panny and Sony, I'll probably get it because of the DVI/HDCP.
Waters_10 is offline
Closed Thread Direct View (single tube) CRT Displays
