How do I view HD "over-the-air" channels on my HD Trinitron? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-05-2012, 03:33 PM - Thread Starter
ArmorOfGod7's Avatar
I just picked up an HD Trinitron and can't figure out how to view the HD channels through it. I'm not currently paying for cable but still get the "over-the-air" channels coming over the wire (co-ax). When I still had my plasma, it picked up the HD channels fine, but I can't figure it out now. My model # is KV-30HS420.
ArmorOfGod7 is offline
post #2 of 6 Old 02-05-2012, 03:45 PM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
Your TV doesn't have a QAM (digital tuner). You will need to subscribe and rent a HD cable box from a cable provider or buy an external clear QAM receiver.
Ratman is offline
post #3 of 6 Old 02-05-2012, 04:42 PM - Thread Starter
Ahhh...I thought all the HD Trinitrons did. Thanks!
post #4 of 6 Old 02-06-2012, 05:40 AM
Ratman's Avatar
Liked: 1029
From Amazon product description:
Sony 30" FD Trinitron(R) WEGA Hi-Scan(TM) TV KV-30HS420 -
Comes with NTSC analog TV tuner. HDTV reception requires optional HDTV tuner and antenna or special HD cable or satellite service.
Ratman is offline
post #5 of 6 Old 02-06-2012, 10:32 AM
P719C1's Avatar
Only model numbers beginning in KD do. Model numbers beginning in KV only have an analog tuner.
You can still get over-the-air HDTV if you purchase an external OTA HDTV tuner. These cost more than your standard low-quality, low-end, at-one-time-coupon-eligible, digital "converter boxes" but are well worth the extra money. Do a bit of research before buying one, since they all seem to fall into at least one of these categories:
  • Expensive
  • Glitchy or prone to functional problems
  • May require additional hardware to work properly
There is a thread in the HDTV Technical section (click here) that lists current and discontinued models.
P719C1 is offline
post #6 of 6 Old 02-06-2012, 12:22 PM
HEYHI's Avatar
I had the same problem. I have an HTPC hooked up to mine via HDMI so the fix was simple. I just bought a PCI tuner card for $30. Works like a charm. Also, if you have a laptop with HDMI, an Expresscard, or USB TV tuner can be had for cheap.
HEYHI is offline
Reply Direct View (single tube) CRT Displays
