Do unshielded speakers affect CRT TVs even if the TV isn't turned on? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-14-2012, 07:32 AM - Thread Starter
shoopdopp's Avatar
Just checking to be sure. Thank you.
shoopdopp is offline
post #2 of 3 Old 03-14-2012, 08:11 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
Why do you ask? Obviously the magnetic field from the speakers doesn't "go away" when the TV is off. But, as long as the TV is off, you will never see how the TV is affected.
I would be more concerned about the effect when the TV is on.
Ratman is offline
post #3 of 3 Old 03-14-2012, 11:24 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
That one does seem odd. The only other condition I can think of is if the stuff has been in close proximity storage. Assuming the speakers are then moved away I would think the TV's power-up degauss would eventually correct any residual affect (let the degauss circuit cool off before repeating).
Floydage is offline
Reply Direct View (single tube) CRT Displays
