Odd curve on Samsung TXT3093WHX/XAA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-29-2012, 03:58 PM - Thread Starter
StlSportsFanatic's Avatar
To start of, I'm new here and don't know much about tv's, but I have a problem with my current one and I'm almost positive there must be some way to fix it.
I have a Samsung TXT3093WHX/XAA, and I use it to play alot of video games and watch a very good amount of sports. I've noticed that the 'geometry' of the screen is VERY weird. There's a noticeable curvature at the bottom (while watching sports, the ticker at the bottom of most broadcasts is un-comprehensible as the set cuts off more than half of the words)
If anyone can help, it would be very appreciated
StlSportsFanatic is offline
post #2 of 2 Old 04-30-2012, 08:56 AM
The Lizard King's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=720504
http://www.avsforum.com/avs-vb/showthread.php?t=1177910
Happy reading. Be SURE to write down your original settings before you make changes.
TLK
The Lizard King is offline
Reply Direct View (single tube) CRT Displays
