Sony Wega-Letter-Numbers Appearing on Screen - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2012, 08:40 AM - Thread Starter
dealer6871's Avatar
Quoted: 13 Post(s)
I have a 32" Sony that's 14 years old attached to a Time Warner cable box. The set has given me good service with no problems. Twice in the last couple of weeks a thin horizontal black box has popped up on the screen containing a series of letters/numbers. A first I thought my cable box was throwing out a code, but the numbers still remained when I turned off the box. They disappeared when I turned the set off and then back on. Both times the box appeared while watching the same science channel.
Anyone ever come across this problem? Thanks.
dealer6871 is online now
Old 05-07-2012, 08:27 PM
neccrttv's Avatar
Start off with checking if Closed Caption is activated in the menu of the TV. You could be in a special CC mode and that channel is transmitting it.
Apart from that... i cant see how your TV could show numbers unless your EEProm is going crazy.
neccrttv is offline
Old 05-08-2012, 12:45 PM
airscapes's Avatar
Quoted: 357 Post(s)
Liked: 289
+1
The service menu does not use a back box..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 05-09-2012, 08:04 AM - Thread Starter
dealer6871's Avatar
Quoted: 13 Post(s)
Thanks. I don't use CC or PIP, but will double check. Just didn't know if that was the way the Sony displayed an error code if there was an internal problem with the set.
Old 05-09-2012, 08:15 AM - Thread Starter
dealer6871's Avatar
Quoted: 13 Post(s)
Old 05-09-2012, 08:37 AM
Ratman's Avatar
Quoted: 1307 Post(s)
Liked: 1042
LOL. I don't use CC or PIP either, but one "oops" on the remote can enable the feature. Just happened this weekend with my wife.
Ratman is online now
