Progressive scan does not work on my CRT TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-25-2012, 08:53 AM - Thread Starter
calter's Avatar
Hello.
I have Samsung CRT model CL-21Z57MQ. I bought 2 years ago approximately.
The problem is that the input component does not work. This came from the factory.
I have tried various component devices PS2, Xbox 360, etc.. I plug it in and it looks good without any problem, but if I put it in progressive mode. The screen is divided in two and the same thing twice and so distorted and altered colors. You can not see almost nothing of the image.
So before you buy another CRT. I'll do my best to fix this. It's a shame, because everything else works perfectly and is also new.
By the way. Enter the Service Menu and set the factory defaults. It did not work. Do not change anything else.
I hope you can help me, thanks.
PS: Sorry my English is not my first language.
calter is offline
post #2 of 15 Old 05-25-2012, 09:01 AM
Ratman's Avatar
Quoted: 1287 Post(s)
Liked: 1028
Did you also set the Xbox and PS2 to output 480p?
And... you are using "red, green, blue" cables, correct?
Ratman is online now
post #3 of 15 Old 05-25-2012, 09:01 AM
gregzoll's Avatar
Liked: 33
Unless this tv was HD capable, which most likely it isn't, that would be why you can not do Progressive. If you have the user manual, it should tell you what it is capable.
gregzoll is offline
post #4 of 15 Old 05-25-2012, 10:04 AM - Thread Starter
calter's Avatar
Yes. Already established the progressive scan option in the bios of the consoles.
Sure, I'm using the component cable for each console specific (red, green and blue)
Connect the consoles to my TV LCD HD ready and is progressive scan works perfectly.
calter is offline
post #5 of 15 Old 05-25-2012, 10:08 AM - Thread Starter
calter's Avatar
Yes have progressive scan function. He says in the manual and also has the component input for that function.
calter is offline
post #6 of 15 Old 05-25-2012, 12:39 PM
gregzoll's Avatar
Liked: 33
Post pad much? I am not illeterate, I was able to comprehend what the OP stated, before you replied exactly what they stated.
they already stated in the first post, that component input does not work on my guess, the set. So that would lead me to believe that right there states what the problem is.
gregzoll is offline
post #7 of 15 Old 05-25-2012, 01:30 PM
blue_z's Avatar
Quoted: 12 Post(s)
The manual for your TV at
http://samsung.6c0.net/man/1632/CL_2...al__ver_1_0_/1
or in English
http://www.manualowl.com/m/Samsung/C.../139545?page=1
state that the component video input accepts only 480i.
No progressive inputs are mentioned.
blue_z is offline
post #8 of 15 Old 05-25-2012, 02:08 PM - Thread Starter
calter's Avatar
If you're right. 5 minutes ago check the back of the TV and next to the component input 480i says in fine print. I know that my TV is not compatible now.
Also thanks for the information.
The big problem now is that before reviewing the entries. Place the service menu and started to change a parameter CL video that said, I guess refers to the model of TV.
As you begin to change from CL to CM, CQ, CZ. The latter the tv is was shut down.
I light it up, but shuts off in 1 or 2 seconds.
The solution is easy in theory, change the parameter back to CL. The problem is that doing in a second, is impossible.
What do you recommend?
calter is offline
post #9 of 15 Old 05-25-2012, 03:14 PM
Ratman's Avatar
Liked: 1028
Stay out of the service menus.
post #10 of 15 Old 05-25-2012, 03:25 PM - Thread Starter
calter's Avatar
Okay but how I can fix the problem?
I turn on the tv on and off in 2 seconds. He was also lit in service menu, but shuts off after 2 seconds. By which I can not change the setting back to CL in just 2 seconds.
calter is offline
post #11 of 15 Old 05-25-2012, 05:30 PM
YeuEmMaiMai's Avatar
Does your TV have a service port? If so, that will be the method of resetting it. You will need the Service Manual to understand how to access the menu or reset the TV
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #12 of 15 Old 05-25-2012, 06:04 PM - Thread Starter
calter's Avatar
If have it. It is entered by pressing Mute, 1, 8, 2, Power. The problem is that it appears the service menu and also turns off after 2 seconds. So I have no time to change the setting.
So any option through the service menu is ruled out for now.
It is a very serious problem I have now ...
Will there be any way to restore the factory settings with the TV off, pressing a button sequence?
I guess not ... But you never know.
calter is offline
post #13 of 15 Old 05-25-2012, 09:13 PM - Thread Starter
calter's Avatar
Investigated in another forum and got the solution. You have to reprogram the eeprom. So unfortunately I have to take it to a technician.
So you can take the item closed.
Also thanks for the help.
calter is offline
post #14 of 15 Old 05-28-2012, 05:46 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Not sure I understand what you mean,but I had a Samsung tv before and when I was in service menu I selected one of the choices that made tv go all black accidentally.
On one of the choices in service menus scroll down to where the choices were Y or N (I think).i changed it to the one it was not on.
Example if Y or N is on line 4
1:::::::::
2:::::::::
3:::::::::
4:::::::::
Scroll down to line 4 and change it to Y or N
Might help
Sorry just looked again and seen you fixed it
Vic12345 is offline
post #15 of 15 Old 05-28-2012, 10:16 AM
SAM64's Avatar
Liked: 78
prove it
SAM64 is offline
Reply Direct View (single tube) CRT Displays
