MegaView XC-3730C issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-12-2012, 09:04 PM - Thread Starter
MegaViewer's Avatar
Hey there. I picked up a MegaView XC3730C the other month for use as a gaming monitor for my older systems and hopefully arcade boards after the supergun is built. Since I got it, I had it in a road case waiting until I moved to try it out. Well I finally moved and went to try it out and much to my dismay, it does nothing. Will not turn on. This sucks as I was quite excited about this thing. Has anybody had a similar experience with one of the Megaview monitors? If so, does anybody have any tips for sorting this out. Possibly a blown fuse or something stupid like that? I've messed around inside CRT arcade monitors a little, but I'm trying to avoid opening it if I don't have to.
MegaViewer is offline
post #2 of 5 Old 06-13-2012, 01:03 PM - Thread Starter
MegaViewer's Avatar
False alarm. Turned out to be a crappy power cable. Very happy with it so far. NES looks fantastic. I can't wait to wire up some RGB cables and test out those compatible systems ( I've got quite a few).
post #3 of 5 Old 06-19-2012, 06:21 PM
fmw63's Avatar
Glad you got it working! It's a real nice monitor. I picked one up 3 or 4 years ago, (government surplus 2/$58),
and everytime the news (WUSA Ch9) comes on, I'm reminded why I don't want to switch to lcd biggrin.gif
fmw63 is offline
post #4 of 5 Old 07-09-2012, 08:53 AM
neccrttv's Avatar
Yep, these monitors are amazing. My XC3716C and my NEC XP37 Xtra (XP3791) are just so amazing on everything you throw at it. I will always be amazed at how much definition the Wii truly has and how much of it can only be found when you truly are in 480p with the component cables.... Final Fantasy Crystal Chronicles and all games are truly a sight to behold....
neccrttv is offline
post #5 of 5 Old 07-15-2012, 09:05 PM - Thread Starter
MegaViewer's Avatar
So far I am loving the monitor for video games. For standard def tv running NTSC composite (saving to get an RTC to run component into rgbhv) it seems that on live action programming, anything that has any sort of gradient shadowing shows up more like concentric rings of similar colors rather than a smooth realistic lighting pattern. Also, my red gain always has to be down to -20 in order for them to not be over saturated. It's a bit odd. If one of you has any suggestions, I'd be more than happy to try them out. Once I get everything squared away, I'd also like to put some quieter fans in this beast, or maybe a velocity controller to slow them down a tad as the 1996 issues are a tad loud when watching at nighttime volume levels.
Also does anybody have any recommendations for a good quality VGA switch box as I plan to connect a bnc to vga cable to the back and terminate all my rgb cables with HD-15 connectors as finding a 5 bnc connector switch box with a decent amount of inputs has proven difficult.
Reply Direct View (single tube) CRT Displays
