Calibrating Mitsubishi 2070SB - AVS Forum | Home Theater Discussions And Reviews
Old 06-20-2012, 10:43 PM - Thread Starter
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Hi! I recently bought Mitsubishi Diamond Pro 2070SB 22" CRT monitor with low hours (8500 hrs) and want to calibrate it to the best picture possible.
All other issues aside, I've found a way to enter factory menu to adjust RGB gain and offset for grayscale calibration (offset is unavailable from the user menu). Here's a link to the service manual: http://www.scribd.com/dh_fool/d/58708278-Diamond-Pro-2070sb-Nec-Multisync-Fp2141sb
So I calibrated gain and offset allright but how do I save the settings? There's an instruction there (ctrl+F -> How to rewrite into address) but I wasn't able to understand the procedure in the end. Please, help.
Elix is offline
Old 06-25-2012, 05:56 AM - Thread Starter
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
I guess I'm on my own with this. I'm not good with HEX codes.
Elix is offline
