How much input lag, on average, do Sony Wega Trinitron CRT HDTVs have? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-06-2012, 04:28 PM - Thread Starter
jameslieb1's Avatar
I'm considering buying one off of Craigslist for gaming. This is in regards to HDMI gaming.
jameslieb1 is offline
post #2 of 3 Old 07-06-2012, 09:17 PM
hoffo's Avatar
Most likely less than what you are playing on now. Unless you are playing on an SD CRT in which case it won't be quite that good.
hoffo is offline
post #3 of 3 Old 07-07-2012, 01:19 PM
CRTFTW's Avatar
Somebody just made a thread about this a few posts down, look at that. As far as I know, the lag numbers are similar amongst most of their CRT HDTV's
CRTFTW is offline
Reply Direct View (single tube) CRT Displays
