Important question about XBR960 service menu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-24-2012, 09:39 AM - Thread Starter
jameslieb1's Avatar
Are there any configurations that can be made in the service menu that could add extra processing of any kind. I game on Xbox 360 with component cables at 1080i with HDPT off, so I should have no lag at all (well, sub-1ms to be precise, like an SD CRT) but I feel like there's still a TINY bit of lag compared to my SD CRT. I changed some options in the service menu to reduce blurriness on the sides of the screen, using posts from this forum as my guide, but naively forgot to make a note of what exactly I changed. I tried looking back in my web history to figure it out but I can't figure out what exactly it was. Please help!
jameslieb1 is offline
Reply Direct View (single tube) CRT Displays
