Sony KV34XBR800 problem. Please help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-14-2012, 03:55 PM - Thread Starter
kevers7290's Avatar
Hi everyone. I recently made a REALLY stupid move and reset the settings in the service menu in an attempt to correct a bowing problem that was plaguing anything watched in 4:3. Now I have an even bigger problem as since I have reset all the values, the menu will no longer allow me to change the view mode! It says "16:9 Enhanced: Auto" and is grayed out. I can no longer access the wide mode settings like I could before. I have the service manual but I am not the most tech-savvy person so it hasn't helped me with this problem. I now know screwing with the service menu was really dumb move but if anyone could give me any guidance as to what values I need to change to re-enable the TV menu items I would be eternally grateful.
Thank you for your time.
kevers7290 is offline
post #2 of 2 Old 09-02-2012, 10:41 AM
homerging's Avatar
Quoted: 31 Post(s)
I came across this old post that might be of some help to you:
http://www.avsforum.com/t/1036990/sony-kv-34hs420-accidentally-reset-service-menu-codes-is-there-a-fix#post_19207416
Resetting the TV's service menu to the defaults is a bad, bad idea unless you really know what you're doing.
homerging is offline
Reply Direct View (single tube) CRT Displays
