Toshiba cf32e50 32" CRT Model Displaying large black rectangular box in bottom half of screen - AVS Forum | Home Theater Discussions And Reviews
Old 09-30-2012, 05:10 AM - Thread Starter
freerunner91's Avatar
My model CF32E50 has been displaying a large black rectangular box on the bottom half of my viewing area during my cable TV input from my Comcast Motorola cable box. Prior to this, there was only audio, then I unplugged the cable box and plugged it back in. Now there is is video, but with the box showing. There is no difference changing it from STD to IHC or HRC in the TV menu. The video is fine on our backup TV using the same cable input, and a DVD input is fine. I am not sure that the problem is, or where to go from here. Thanks.
freerunner91 is offline
Old 09-30-2012, 05:30 PM
neccrttv's Avatar
Start by checking if subtitles are activated. If the CC is in text mode it will show a black box exactly like you describe. It should be on the remote and written C.C. Be sure its off.
neccrttv is offline
