XBR960 static issue: failing capacitor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-14-2012, 03:17 PM - Thread Starter
jameslieb1's Avatar
I'm having an issue with my XBR960. The picture, no matter what the source is, has a layer of static/noise over it. Depending on the brightness, contrast, etc. some settings make it more visible while others make it blend in to the picture more, but no matter what it causes eyestrain and makes the picture look worse. I've been trying to research what could be causing this problem and the only the thing I can find is a possible failing capacitor. (Source: http://shmups.system11.org/viewtopic.php?f=6&t=43091) Money is not an issue so if I need to replace a capacitor I have no problem with that, however I would first want to know if that's definitely what needs to be done to make the static go away and also which capacitor I would need to replace. All help is appreciated.
jameslieb1 is offline
post #2 of 3 Old 11-15-2012, 03:05 AM
homerging's Avatar
Quoted: 31 Post(s)
Does this not go away if you turn HDPT back on?
There are a couple of big 250v caps that are probably found in your model which are known to sometimes fail. They're discussed in this thread
http://www.racketboy.com/forum/viewtopic.php?f=52&t=32118
You need to observe electrical safety procedures as there is high voltage associated with the insides of CRTs and larger electrolyte capacitors.
homerging is offline
post #3 of 3 Old 11-23-2012, 08:06 PM - Thread Starter
jameslieb1's Avatar
Changing HDPT does not affect it. I really don't know how to go about solving this problem so I really need some guidance. What steps should I take to figure out what component of the TV is causing the problem? Or is this something that can be fixed in the service menu?
Reply Direct View (single tube) CRT Displays
