Panasonic picture shrinks to 1/2" bright horizonal line in middle of screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-16-2012, 10:51 AM - Thread Starter
T-Hawk's Avatar
I have a Panasonic 32" (don't know the model number off the top of my head) that I use mainly to watch DVDs in my hobby room while I am working on other stuff. Recently it developed a problem where the picture will get grainly (almost as if it was a VCR and the tracking was off). Then suddenly the entire screen goes black except for about a 1/2" VERY BRIGHT horizontal line across the center of the screen. The only fix I have found is to jump up and down on the floor as this vibrates the TV and temporarily returns the picture to normal. I have produced the problem with 2 different sources so I know it is the TV.
Any ideas what this might be and if it is fixable?
T-Hawk is offline
post #2 of 3 Old 11-19-2012, 01:50 PM
SAM64's Avatar
Liked: 78
Vertical deflection problem, probably a cold solder joint around a driver transistor.
SAM64 is offline
post #3 of 3 Old 11-20-2012, 06:05 PM - Thread Starter
T-Hawk's Avatar
Thanks! Now that I know the term "vertical deflection" I was able find a lot more info out there.
The model number is actually a CT-27D31. If I have time this weekend I may open it up and look around inside. I happen to have a soldering iron sitting right next to the TV! Any advice on finding a cold solder joint?
T-Hawk is offline
Reply Direct View (single tube) CRT Displays
