Oddball JVC 7-pin Y/C to Standard S-Video? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-30-2012, 07:17 AM - Thread Starter
daskrabs's Avatar
I picked up a JVC VM-R190SU monitor last night that has these connectors on it for S-video in and out:
It's called a JVC 358 connector, or EIAJ 7-pin connector, used for old video cameras and JVC's own S-VHS decks. I'd like to get adapters (or cables) so that I can plug in a standard s-video mini-DIN. Anyone know where I can source something like that? I realize I may have to roll my own.
daskrabs is offline
post #2 of 12 Old 11-30-2012, 12:03 PM
SAM64's Avatar
Liked: 78
They look like "Hirose" connectors.
SAM64 is offline
post #3 of 12 Old 11-30-2012, 12:40 PM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Originally Posted by daskrabs View Post
I'd like to get adapters (or cables) so that I can plug in a tandard s-video mini-DIN. Anyone know where I can source something like that? .
Any info in regard to an adapter/converter as requested by the OP?
Ratman is online now
post #4 of 12 Old 11-30-2012, 01:35 PM
SAM64's Avatar
Liked: 78
I haven't googled any for him....have you?
SAM64 is offline
post #5 of 12 Old 11-30-2012, 02:03 PM
Ratman's Avatar
Liked: 1022
Whether you believe me or not.... yes I did. I could not find any Y/C 358/422 cable converter/adapter to standard S-Video DIN. I also searched around for "Hirose" to no avail. Therefore.... refer to post #3.
Any enlightenment would be appreciated by everyone
post #6 of 12 Old 12-01-2012, 06:18 AM
ybsane's Avatar
Quoted: 93 Post(s)
Liked: 34
ybsane is offline
post #7 of 12 Old 12-01-2012, 06:20 AM
ybsane's Avatar
Quoted: 93 Post(s)
Liked: 34
http://chiclassiccomp.org/docs/content/other/JVC_VM-R190SU_Monitor_InstructionBook.pdf
Here is the monitor document.
All Comments made are my own and not of my employer.
ybsane is offline
post #8 of 12 Old 12-01-2012, 08:52 AM
Ratman's Avatar
Liked: 1022
Based on what can be seen on the links provided, it's appears the "connectors" can obtained, but no "converter/adapter" (from 7 pin to standard 4 pin DIN). So.... I guess the OP will have to make a conversion cable/connector.
post #9 of 12 Old 12-02-2012, 08:59 AM
SAM64's Avatar
Liked: 78
Yeah, he mentioned that in his opening post....but hey, thanks for contributing wink.gif
SAM64 is offline
post #10 of 12 Old 12-02-2012, 09:35 AM
Ratman's Avatar
Liked: 1022
As always, you're correct again. I did read his opening post. But hey... your "contributions" deserve a thanks also.tongue.gif
post #11 of 12 Old 12-04-2012, 01:02 PM - Thread Starter
daskrabs's Avatar
Thanks to all for the responses. I've decided to roll my own cable for the input with an s-video cable I have laying around and this:
http://www.digikey.com/product-detail/en/RPC2-12P-7S(71)/HR1816-ND/1125811
And for output there's this:
http://www.bhphotovideo.com/c/product/133514-REG/Comprehensive_S4P_S7P_6HR_S4P_S7P_6HR_Male_S_Video_to.html
daskrabs is offline
post #12 of 12 Old 12-05-2012, 06:55 PM
CRTFTW's Avatar
I wouldn't mess with all that. Instead, I would just open the monitor and solder in a normal s-video connector. Solder points will probably be large and impossible to mess up.
CRTFTW is offline
Reply Direct View (single tube) CRT Displays
