CRT monitor goes blank but stays on... maybe the power supply? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-26-2012, 07:03 AM - Thread Starter
CRTFTW's Avatar
So I got an NEC FP2141SB-BK for free on craigslist, has very good color and a high scan rate, seems like it might be the exact same monitor as my Lacie.
Problem is that after it is on for an hour or two, it will completely lose picture. It will flash a couple times then go black, but the power light stays green. If I turn it off and on, then I will get picture again for anywhere from a few minutes to another hour or two.
Is this most likely a problem in the power supply? The picture is perfect, no sign of age there, so I'm thinking it's not a problem with the tube itself.
CRTFTW is offline
post #2 of 3 Old 12-27-2012, 05:54 AM
JA Fant's Avatar
Quoted: 233 Post(s)
Liked: 327
Yes, it will be a shoot out between the power supply or picture tube.
JA Fant is offline
post #3 of 3 Old 12-27-2012, 09:29 AM - Thread Starter
CRTFTW's Avatar
So is there a way to diagnose these things? Should I look for a blown capacitor or anything in particular on the power supply?
CRTFTW is offline
Reply Direct View (single tube) CRT Displays
