Just got my new (old) sony kv14 LT1U, can't seem to save geometry changes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-23-2013, 02:55 PM - Thread Starter
systemchris's Avatar
I found the geometry was annoying me for playing my sega saturn, so i put it into service menu and i adject the screen positioning to suit my eyes better...
Every forum i've read says you adjust the number to what you want, then you press mute then enter. My original remote doesn't have an enter button
it looks like this
this is the default screen on service mode entry
and this is the screen i altered geometry on
I seem to be at a loose end as what to do. spent like an hour or 2 trying different things like mute and 0 or mute and then OK button but nothing seems to save the settings
systemchris is offline
post #2 of 4 Old 02-23-2013, 03:04 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Do a search for the service manual. If you can find it, it will tell you what to do.
How about the buttons on the TV itself, is there an enter there?
When you press mute does the word WRITE appear in RED? If so then try every other button to make write turn from RED to Yellow. If you have done this already good luck finding the manual, I could not fine one!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 4 Old 02-23-2013, 03:33 PM - Thread Starter
i've been struggling to find a manual all day, it must be alterable, and i have the original remote
just baffling me so much
so you're saying changes should be seen as "write" and that goes from red to yellow? hmm ill give it a go
tried all buttons, only visible change buttons
standby is off
the screen button removes all changes and goes back to normal mode
menu button goes to a screen with green text all over the screen, and removes any changes, pressing menu again reverts to options for geometry etc
nothing seems to suggest writing, a similar model tv with the same remote, just bigger's manual says to make changes, then press menu and switch off to prevent further altering, but afaik, theres always a button to press to write changes so to just make sure it's a wanted change :s
to quote:
Service adjustments to this model can be performed using the
supplied remote Commander RM-932.
‘TT—’ will appear in the upper right corner of the screen.
Other status information will also be displayed.
3.
Press ‘MENU’ on the remote commander to obtain the following
menu on the screen.
4.
Move to the corresponding adjustment item using the
up or down arrow buttons on the Remote Commander.
5.
Press the right arrow button to enter into the required menu item.
6.
Press the ‘Menu’ button on the Remote Commander to quit the
Service Mode when all adjustments have been completed.
Note :
Before performing any adjustments ensure that the correct model
has been selected in the ‘Model Setting’ menu.
After carrying out the service adjustments, to prevent the
customer
accessing the ‘Service Menu’ switch the TV set OFF and then
ON
post #4 of 4 Old 02-24-2013, 04:36 PM
blue_z's Avatar
Quoted: 12 Post(s)
The "Enter" button is usually below the "9" and to the right of "0".
The button below the "7" and to the left of "0" is usually "Jump (channel)".
Regards
blue_z is offline
Reply Direct View (single tube) CRT Displays
