Sony KV-34XBR800 directv HR34 problem - AVS Forum | Home Theater Discussions And Reviews
Old 03-06-2013, 03:35 PM - Thread Starter
jtown017's Avatar
Quoted: 13 Post(s)
I still have one of my tvs as the sony kv-34xbr800. Works wonderful still.
Anyways, i recently changed over to directv from cable and now have HR34 (genie) and the clients for the other tvs.
The problem is with this tv, the menu,info bar of the directv is oversized.
i.e. It is cutoff on the right/left side of the tv. Or if you go to the menu the clock is cut off. It is quite frustrating.
The tv ratio on the HR34 is set up to be 16:9.
Now I have tried to change stuff on the actual tv but it is stuck in full mode (assuming because it was HD programing, but even when viewing non hd it wont budge). I think it is an overscan problem with the tv.
Any ideas would be greatful!
jtown017 is offline
Old 03-07-2013, 11:15 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
You could try changing the output from the HR34 to a fixed resolution (i.e. 720p) and see if that lets your TV change ratios.
Alan P is offline
Old 03-07-2013, 05:09 PM - Thread Starter
jtown017's Avatar
Quoted: 13 Post(s)
i already have the HR34 fixed to 720p, 1080i fixed resolution.
jtown017 is offline
Old 03-08-2013, 07:56 AM
Alan P's Avatar
Liked: 3324
Alan P is offline
Old 03-08-2013, 01:38 PM - Thread Starter
jtown017's Avatar
Quoted: 13 Post(s)
Try 480p...?
k ill try tonight
jtown017 is offline
Old 03-08-2013, 01:45 PM - Thread Starter
jtown017's Avatar
Quoted: 13 Post(s)
First image is the problem i am having
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 75
second image is what it would look like with no problem
jtown017 is offline
Old 03-08-2013, 02:42 PM
Alan P's Avatar
Liked: 3324
Ummm...may be a stupid question - but, why don't you just use the "Full Pixel" setting??
Alan P is offline
Old 03-08-2013, 04:09 PM - Thread Starter
jtown017's Avatar
Quoted: 13 Post(s)
i apologize. i should have taken my own photos. These photos arent of my tv but the problem is exactly the same. so the menu and settings are not there.
i should have clarified it more.
the effect of the menu being cut off is what i am experiencing but the settings are not my tv at all. it is still a sony kv-34xbr800 (ten years old)
above picture is the problem i am having
below is good on my other tv
jtown017 is offline
Old 03-08-2013, 07:43 PM
LiquidSnake's Avatar
Quoted: 14 Post(s)
Your only hope is standard menu or service menu settings to try to pull back some of that overscan. Please, when you decide to do this, write down EVERY setting, or take photos (clear ones) of every menu. If you start changing service menu settings and do not document your television's unique service menu settings first, you will never be able to go back to the starting point if you take things too far.
Don't be one of "those guys" who screws up their TV then looks everywhere for default service menu settings that don't exist.
LiquidSnake is offline
Old 03-09-2013, 10:38 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
How is the fit using another source?
I have a similar problem on my Panny 34" WS HD CRT with certain DVDs on my Sony Blu-ray player upscaled to 480p (component connection, no DVI or HDMI on this set); all I get are two aspect settings - one is squeezed or stretched (I forget which) and the other is zoomed (I'm assuming your image isn't squeezed or stretched as I can't tell from the pic). I end up having to stay with 480i where the Panny offers many more aspect choices.
If the fit is OK with another source try combinations of other settings (Genie and TV).
For one try 480i.
Try the Genie set to 4:3.
Try component connection, it still provides analog HD (I assume you're using DVI).
For all your tests try different combinations of Genie and Sony aspect settings when available. Fun matrix of tests so maybe write it down as you go, Design Of Experiments or DOE.
Floydage is offline
