Sony KD-34BR970 HDTV CRT television Start up Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-12-2013, 12:27 PM - Thread Starter
Lapax's Avatar
I am looking to dianose an ongoing and slowly progressive problem, I having with my Sony WEGA HDTV model KD-34BR970. When it is initially turned on, has 3 to 4 inch tall horizontal band across center of screen with distorted blurry lines. The problem resolves itself after a few minutes as the band narrows down to one line across the screen and disappears altogether and is picture perfect until the next time tv is turned off and then restarted. The problem has been gettting worse for the last year or so. I first noticed it when it the blurry band was less than an inch tall and disappeared in less than a minute. Now it takes up to 10 minutes to resolve itself. The set otherwise operates perfectly with consistant excellent vibrant HD clarity and color, once it has warmed up. Does anyone have a best guess what circuit is starting to fail and the difficulty and expense to repair?
Lapax is offline
post #2 of 2 Old 03-30-2013, 04:25 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
I can't answer that one try Videokarma forum /sub forum rectangular tube screen televisions .
lot of techs over there with crt repair experience sounds like a circuit part /or board fault perhaps even a failing capacitor .
link http://www.videokarma.org/forumdisplay.php?f=45
tubetwister is offline
Reply Direct View (single tube) CRT Displays
