540p/60hz! ANYONE GET THIS MODE WORKING ON A CRT HDTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-13-2013, 06:20 PM - Thread Starter
RetroFan786's Avatar
As the title suggests...has anyone been able to get this mode successfully working on a CRT HDTV? How does it look?
Do you get scanlines like in 240p mode on SD CRTs?
Anyone with a Panasonic CRT HDTV TAU series? How does the 540p mode look on that if you got it working?
Anyone with a Lumagen Visionpro video processor? How are the results with 540p/60hz on that processor?
RetroFan786 is offline
post #2 of 7 Old 04-15-2013, 02:49 AM
hoffo's Avatar
I have a Toshiba 30HF66 that has 540p mode. It only works over component or HDMI and only when sending a 480p source signal (at least on this TV). No 480p source = 1080i even with 540p selected. I've found 1080i looks better and tend to use it more. I only use 540p (480p) when using my Wii console for gaming. 1080i looks better for HD video sources and upscaled DVD.
hoffo is offline
post #3 of 7 Old 06-23-2013, 09:00 AM - Thread Starter
Bump
Does that Toshiba show scanlines (the black lines) between each drawn line that the T.V displays for the Wii?
post #4 of 7 Old 06-24-2013, 01:41 PM
hoffo's Avatar
I don't believe it does but it's been a while since I used it last. Aren't scanlines something you'd only see with 240p content?
This page might be of interest to you: http://scanlines.hazard-city.de/
hoffo is offline
post #5 of 7 Old 07-30-2013, 02:46 PM
homeomnimax's Avatar
A friend had a 540p mode working with the output of an ATI card onto a 32 inch HD CRT Sony, there were no scan lines or jitter, it looked very nice. I don't have the details because I don't have contact with that person anymore but they used it as a computer monitor at the time.
homeomnimax is offline
post #6 of 7 Old 08-24-2015, 11:54 PM
Liked: 0
Anyone know of a way to get a CRT HDTV to display in 480i so that DIRECTV SD will look right???
JohnHammock is offline
post #7 of 7 Old 08-25-2015, 06:41 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
Asking the same question in various old threads will not help. Stick your original thread.
Ratman is offline
Reply Direct View (single tube) CRT Displays
