KV-34HS420 Trinitron - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-12-2013, 06:23 AM - Thread Starter
Preston49's Avatar
My Sony Trinitron is not working. It comes on for a few seconds and then promptly shuts off. There is a flashing red light on the front of the TV (Stand by/timer) that is flashing 6 times intermittently. Any ideas how to fix.
Thanks for you help.
Preston49 is offline
post #2 of 4 Old 06-17-2013, 09:53 AM
gringito's Avatar
hello i noticed nobody has replied to your easy question there are TONS of posts on this sony problem it is probably two IC that need replaced google my sony flashes 6 times .......study the results!pretty easy repair and almost always is the problem!!!
gringito is offline
post #3 of 4 Old 06-17-2013, 12:51 PM - Thread Starter
Preston49's Avatar
I decided to trash the unit since it was going to cost me $150 to repair and I didn't feel I had expertise to fix it myself.
We ended up getting a FREE 32HS Trinitron.
Best,
Preston
post #4 of 4 Old 06-18-2013, 06:21 AM
gringito's Avatar
cool preston ! the gods are smiling on you! feed it a nice HD signal and it should impress! have agreat day! Brian
gringito is offline
Reply Direct View (single tube) CRT Displays
Sony Kv 34hs420 34 Inch Fd Trinitron Wega Hd Ready Crt Tv
