Does it make a difference - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-13-2013, 07:10 PM - Thread Starter
kngpn300's Avatar
Does high quality or regular composite cables make a difference and how long they are for picture quality
kngpn300 is offline
post #2 of 3 Old 06-14-2013, 09:12 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Mostly deja vu per the other threads you started. Maybe you enjoy instigating arguments between us regulars here. biggrin.gif
Suggestion: Try using more descriptive subjection lines. For example - 'Question about composite cables' rather than "Does it make a difference." wink.gif
Floydage is offline
post #3 of 3 Old 06-14-2013, 10:47 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1030
High quality or regular cable.... composite is composite. It is not a video connection that is really worth discussion in every thread that you start.
As for length.... video quality will degrade over cable distance.
Say "No" to drugs!
Ratman is online now
Reply Direct View (single tube) CRT Displays
