Convergence problem with Sony WEGA KD-34XBR970 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-27-2013, 12:36 AM - Thread Starter
bjp9860's Avatar
I bought this 34" behemoth of a CRT used a few years ago and had to adjust convergence at that point as it was pretty far off.  It's been fine for years, even through two moves, but today I noticed that it's way off again (almost 1/2" horizontally).  The blue is separated to the left while the red is separated to the right, so I thought for sure YBWU and YBWL in service mode were going to do the trick.  But, when I went to adjust them, nothing happened.  I tried moving both values all the way down to 0 and all the way up to 63, but there was zero visible change.
Is it possible the dynamic convergence system has failed?  If so, how hard/expensive is that to repair or replace, and where would I go to find information on how to do it?  I've heard that the minimum cost of getting a technician is probably close to twice what I spent on the TV to begin with, so that's probably not an option.  But, I'm sort of a EE so I may be able to work out the fix.
Any suggestions?
bjp9860 is offline
post #2 of 3 Old 09-27-2013, 06:19 AM
JA Fant's Avatar
Quoted: 233 Post(s)
Liked: 322
Welcome! bjp.
There is a thread about your 970 here in the forums. Hopefully, someone has posted a remedy to your situation. If not, post the query in the ISF Calibrators thread. There are several guys who still perform treatments to the Sony 960/970 CRT sets.smile.gif
JA Fant is offline
post #3 of 3 Old 10-04-2014, 08:05 PM
Liked: 0
bjp: Did you ever have any luck in repairing the convergence issue on your KD-34XBR970?
I have the same issue and may play with this set before its condemned to the scrap yard.
JVG1 is offline
Reply Direct View (single tube) CRT Displays
