Help with Sony KV-27HS420 - AVS Forum | Home Theater Discussions And Reviews
Old 10-16-2013, 09:54 PM - Thread Starter
fkie's Avatar
Hi, I have the Sony KV-27HS420 Hi-Scan, and it has problems because the picture flickers/rolls a lot in all the inputs except HDMI. I observed that the menu box isn't affected by the flickering. Plus, in the HDMI input, the colors are just shades of green and red, on the other inputs, the colors are ok, and again the colors of the menu are ok on HDMI. Please I need advice on what's going on with the tv. Thanks in advance.
fkie is offline
Old 10-19-2013, 04:06 PM - Thread Starter
fkie's Avatar
Please help me!
fkie is offline
Old 10-19-2013, 06:18 PM - Thread Starter
fkie's Avatar
Seems like it has to do with "vertical hold", do you know how to correct or calibrate it?. The issue is like this video:
fkie is offline
Old 10-20-2013, 09:00 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
What are you hooking up to it? Try something else, something you know worked OK (somehow I suspect it's your source/source settings).
Floydage is offline
Old 10-20-2013, 10:09 AM - Thread Starter
fkie's Avatar
Hi, thanks for the reply, the issue is present in all the inputs, even the antena, and all the analog inputs, composite and component. The digital input HDMI only has the color issue. I tried various DVD players, videogame consoles and bluray players and all they had the issue, all of them worked fine in other tv. Do you have any idea of what's causing this?
fkie is offline
