How does scaling work in CRTs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-07-2013, 07:50 AM - Thread Starter
pqwk50's Avatar
My CRT says it can display 480i, 480p, 720p, and 1080i. But does it effectively have a "native resolution" like LCD & Plasma TVs do requiring some sort of scaling when dealing with different image resolutions?
For example, if the CRT is fed a 480i image, does it have to scale it in any way? An LCD TV would have to scale a 480i source to 480p (at a minimum).
pqwk50 is offline
post #2 of 7 Old 11-07-2013, 08:58 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Floydage is offline
post #3 of 7 Old 11-09-2013, 03:01 AM
hoffo's Avatar
While CRTs don't have native resolutions, when speaking of HD CRT tvs they are usually made with 1080i in mind. Most will only display 480p / 540p and 1080i. 720p is either scaled to 1080i or 540p and not displayed as actual 720p. When speaking of CRT computer monitors or high end presentation monitors these are usually capable of 720p and sometimes even 1080p or beyond. Dot pitch of the display is what is important especially for CRT computer monitors. For example I have a 17" Sony CRT PC monitor that is 16" viewable with .24 dot pitch and according to the manual the recommended resolution is 1024x768. I run it at 1152x864 @85 Hz and it can do up to 1600x1200 @ 60 Hz but text legibility and sharpness seem to be best around the recommended resolution.
hoffo is offline
post #4 of 7 Old 11-10-2013, 01:28 AM
LiquidSnake's Avatar
Quoted: 14 Post(s)
A CRT doesn't scale its output. The spread of the electron beam is adjusted and this gives you the resultant resolutions. The only reason a television CRT uses just a few resolutions (480i/p 1080i) is because the circuits driving them weren't made to do other resolutions due to a general lack of need. They are still not strictly scaling in the manner you are thinking of.
LiquidSnake is offline
post #5 of 7 Old 11-10-2013, 09:12 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
I'd read somewhere that 1080p required too much expensive circuitry for a CRT TV, something to do with much higher power supply requirements and proportional to screen size (hence TVs vs. monitors). I think maybe the same for the most part with 720p as the requirement increases with progressive scan at higher resolutions. So I'm wondering if this handful of HD CRTs that can do 720p have beefier circuitry or are just converting the signal before scanning?
Floydage is offline
post #6 of 7 Old 11-10-2013, 06:32 PM
blue_z's Avatar
Quoted: 12 Post(s)
I'd agree with the first half ("expensive circuitry") more than the latter half ("power supply requirements"). Low-persistence phosphors and high-bandwidth electronics seem to escalate in price a lot faster than power supply capacity.
"TVs vs. monitors" is an ambiguous comparison. Video monitor? Broadcast monitor? Computer monitor? The silly "TV/monitor" marketing term applied to consumer-grade TVs with video inputs?
720p has a refresh rate of 45KHz, whereas 1080i is 33KHz and 480p is 30KHz.
Or in other words, 1080i requires only a 10% increase in refresh rate over 480p, but 720p requires a 50% increase.
So the answer depends on the cost of higher bandwidth versus costs of a deinterlacer+scaler. Or, in the days before ATSC tuners, simply reject 720p input.
I've seen one early CRT HDTV that would accept a 1080i video signal, but not a 720p. The electronics and tubes (it was a rear projector) didn't have the bandwidth to do 720p, and a deinterlacer+scaler wasn't inexpensive enough at the time. (It didn't have an ATSC tuner to nix that question.)
I have a flaky CRT projector that can display 1080i without a problem, but has issues with (the higher refresh rates of) 720p as the unit warms up. Seems like as the PJ heats up to normal operational temperature, the bandwidth capability of the circuitry decreases. The cause is not likely to be a power supply issue because the PSU has a cooling fan, whereas the CRT electronics rely solely on natural convection for cooling.
Regards
blue_z is offline
post #7 of 7 Old 11-11-2013, 09:01 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Good points and related. They claimed the higher speed required of a CRT required much more charge in the high voltage power supply (and the requirement went up rapidly, like you show with the refresh rate). So based on this it would not only have more expense due to higher bandwidth circuitry but for the more expensive section of the TV's power supply as well. Think about it - CRT HDTVs were competing with plasmas so why wouldn't they also be capable of 720p (or higher? was plasma capable of 1080p back then?). And then when ATSC tuners were integrated there had to be a conversion for the 720p stations.
Sorry, I got lazy and should have wrote computer monitor. Yeah I'd like to forget about that silly TV/monitor marketing term. smile.gif
Floydage is offline
Reply Direct View (single tube) CRT Displays
