Sony kv25xbr off center/wavy edges - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-29-2013, 06:13 PM - Thread Starter
JemmyPaeg's Avatar
I recently got hold of a Sony kv25xbr, probably a good 25 years old, rgb, external speaker connections, the works. Love the look of it however I've noticed the edges are quite distorted, the top edge is fine, however the bottom one is slightly curbed inward and the sides don't exactly line up. Hopefully this picture kind of shows what I mean, you can see the bottom doesn't follow the curve of the screen, the left is quite a bit off center, and the right is also curved inwards and cuts off a very small amount in the bottom right corner. I don't mind too much however if there is anyway to calibrate it that would be amazing.
JemmyPaeg is offline
post #2 of 2 Old 05-16-2014, 10:09 PM
RonAlam's Avatar
Quoted: 62 Post(s)
Liked: 52
have adjusted the H-Sync pod inside the TV?
RonAlam is offline
Reply Direct View (single tube) CRT Displays
