Native resolution on Samsung Tantus CRT HDTV - AVS Forum | Home Theater Discussions And Reviews
Old 01-18-2014, 01:51 PM - Thread Starter
fkie's Avatar
Just like the title, anyone knows the native resolution of Samsung Tantus CRT HDTVs that supported 480p and 1080i signals, not the slim fit models, I'm referring to the ones that came out before. Thanks!
fkie is offline
Old 01-18-2014, 02:27 PM
Ratman's Avatar
Quoted: 1135 Post(s)
Liked: 865
Was there a particular size and/or model number that you have a question about?
Tantus came in various "flavors".
Ratman is offline
Old 01-18-2014, 08:15 PM - Thread Starter
fkie's Avatar
There is a Samsung Tantus model that has a VGA PC connector, the model no. is CT32Z7P and the user manual is here:
http://downloadcenter.samsung.com/content/UM/200304/20030413053221937_K55A_ENG_SEM.pdf
Do you know if this tv has the highest resolution of the Samsung Tantus lineup?, if not, which one has the highest resolution?
fkie is offline
Old 01-19-2014, 06:14 AM
Ratman's Avatar
Liked: 865
AFAIK, direct view CRT's only "natively" display 480p/1080i.
Ratman is offline
Old 01-19-2014, 08:27 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Indeedy, CRT's have variable resolutions unlike their fixed (native) resolution flat panel counterparts:
http://en.wikipedia.org/wiki/Native_resolution
As far as 720p, it's quite a rarity for CRT's and the ones that can accept that input may just be upconverting it to 1080i.
Floydage is offline
