AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Direct View (single tube) CRT Displays (http://www.avsforum.com/forum/64-direct-view-single-tube-crt-displays/)
-   -   Sony Trinitron KV-32V16 Periodically Shifts Tints Green (http://www.avsforum.com/forum/64-direct-view-single-tube-crt-displays/1513596-sony-trinitron-kv-32v16-periodically-shifts-tints-green.html)
justaplasmaguy 01-23-2014 06:18 AM
Hi Everyone,
I just picked up this CRT listed on Craigslist, and after a tiring and not so gentle transport, plugged it in to find that every 5 or so minutes, the picture will take a shade of green within a second. It stays that way for maybe 5 to 15 seconds, then returns to a neutral, natural color. I happen to have decided to watch an old black and white movie, and it's very clearly doing this, but also I think it may shift slightly red some of the time, but I'm not sure if that's just my eyes adjusted to the slight green when returning to white... I think that might very well be the case though because I only think I see the red some of the time, and never quite looking the same.
It's a shame this is happening because when it returns to normal, it looks surprisingly great. The black and white movie looks so purely black and white... Then suddenly it shifts slight green and it is so clearly spoiling the viewing. Otherwise, you don't really notice it too much when playing a video game.
Another thing is that when I first realized this was happening, I noticed that when it shifted back to normal, I thought I could hear that usual CRT prickling static sound - maybe degaussing?
The guy I got it from said it was working fine and seemed helpful, so I don't know if he just omitted this issue or if it was caused by the rough transport. I can't really find any explanation or solution searching online with general, vague descriptions of what's happening. I opened up the back of the TV to see if there was anything obvious, but all I've really found is a pretty dusty interior that I intend to blow clean with some canned air later today.
I'm really hoping someone knows what this could be, and even better, knows a solution that I could hopefully do myself.
22point8 01-31-2014 07:17 AM
Could be a loose neck board, the stuff that holds it in place deteriorates over time, on my PVM 2044QM built in 1990 I had a problem where after being on for 10 minutes, colour would shift green or pink for a few minutes then go back to normal. Now its working normally.
Wiggle it back and forth until it comes off, then check for dirt, and wiggle it back on as tight as possible, obviously do this with the power off and press the power button a few times to discharge capacitors.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
