Philips 28HT5405/01Z CRT how to access Service Menu ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-10-2014, 02:26 AM - Thread Starter
forks's Avatar
hi all,
anyone know to open up the service menu on a Philips 28HT5405/01Z (which is still in hotel mode by the way) ?
Things that I've tried so far:
1) hitting " 319753 mute " on the remote will open the basic menu
2) hitting " 062596 menu " (as well as any of these http://www.riddledtv.com/forums/philips-magnavox-service-menu-codes-plasma-lcd-crt-rptv-t288.html)
will do nothing, the menu itself is blocked maybe because of hotel mode
3) on channel 38 holding " vol+ and vol-" for 3 seconds or "channel+ and vol-" for 3 seconds does not disable hotel mode
anyone ? thanks
forks is offline
post #2 of 10 Old 02-10-2014, 07:04 AM
jts1957's Avatar
When the set is in the High Security Mode, the Setup
menu can be accessed only by a T374AH
Institutional Set-up Remote Control (RG4172BK).
When the set is in the Standard Security Mode the
Set-up Menu may be accessed with a guest remote
control (like the RC2882) by a sequence of commands.
5.2.1 Service Default Alignment Mode (SDAM)
Purpose
• To change option settings.
• To create a predefined setting to get the same
measurement results as given in this manual.
• To display / clear the error code buffer when leaving SDAM
with “standby” key on remote control.
• To override SW protections.
• To perform alignments.
• To start the blinking LED procedure.
Specifications
• Tuning frequency:
– 475.25 MHz
• Colour system:
– PAL
• All picture settings at 50 % (brightness, colour contrast,
hue).
• Bass, treble and balance at 50 %; volume at 25 %.
• All service-unfriendly modes (if present) are disabled, like:
– (sleep) timer,
– child/parental lock,
– blue mute,
– hotel/hospitality mode
– auto switch-off (when no IDENT video signal is
received for 15 minutes),
– skip / blank of non-favourite presets / channels,
– auto store of personal presets,
– auto user menu time-out.
• Operation hours counter.
• Software version.
• Option settings.
• Error buffer reading and erasing.
• Software alignments.
How to Enter SDAM
Use one of the following methods:
• Use a System 7 remote control type T374AH (RCtransmitter
RG4172BK) and key in the code ‘062596’
directly followed by the ‘M’ (menu) button or
• Short circuit jumper wires 9252 and 9275 on the mono
carrier (see Fig. 8-1) and apply Mains. Then press the
power button (remove the short circuit after start-up).
Caution: Entering SDAM by short circuiting wires 9252 and
9275 will override the +5V-protection. Do this only for a short
period. When doing this, the service-technician must know
exactly what he is doing, as it could lead to damaging the set.
forks likes this.
jts1957 is offline
post #3 of 10 Old 02-10-2014, 09:50 AM - Thread Starter
forks's Avatar
hi jts and thanks for the reply,
so if I understand correctly I need the " System 7 remote control type T374AH " ?
I don't know anything about short circuiting jumper wires but I'm guessing it can be dangerous...
In any case I only need the service menu to change h-line value to address an overscan problem but if it means buying a remote it's probably not worth it...
forks is offline
post #4 of 10 Old 02-10-2014, 10:36 AM
jts1957's Avatar
Could not find 'h-line value' adjustment anywhere in the SM.
FWIW (note: click right hand enlarge image)- http://www.replacementremotes.com/ANDERIC/Buy-RR2573-Philips-Master-Setup-RR2573-Commercial-TV-Remote-Control.html
forks likes this.
jts1957 is offline
post #5 of 10 Old 02-10-2014, 10:39 AM - Thread Starter
forks's Avatar
right sorry, I think it's H SIZE...basically the width of the screen value that you decrease to address horizontal overscan problems...
thanks for the link, I might see if I can get a cheap one or even maybe borrow one from somewhere.
forks is offline
post #6 of 10 Old 02-10-2014, 11:11 AM
jts1957's Avatar
Only place I see 'width' mentioned is on sets with E-W correction.
I believe 'HOR. AMPLITUDE' in 'Geometry' would be equivalent
As usual, WRITE down parameter value(s) before making change(s) and realize that if certain parameters are changed (or certain resets performed), the TV may never operate correctly again!
forks likes this.
jts1957 is offline
post #7 of 10 Old 02-10-2014, 12:12 PM - Thread Starter
forks's Avatar
hor. amplitude sounds about right, one last question: once in the SDAM how do you switch from High Security Mode to Standard Mode ? or is this something that cannot be changed with any remote, even the T374AH ?
forks is offline
post #8 of 10 Old 02-10-2014, 03:24 PM
jts1957's Avatar
NOT SDAM mode.
PHILIPS Institutional TV - Instructions for use = aka YOUR set's 'User Manual.' (might want to DL pdf from Philips site)
Page 7 (of pdf):
Accessing the Set-up Menu
Page 10 (of pdf):
• Security
The menu function "SECURITY" allows the user
to select one of two states "HIGH" or "STANDARD".
The default is "STANDARD".
While the set is in the Security High Mode the setup
menu can only be accessed by a T374AH
While the set is in the Security Standard Mode the
remote control by a sequence of commands.
forks likes this.
jts1957 is offline
post #9 of 10 Old 02-11-2014, 04:40 AM - Thread Starter
forks's Avatar
I see, sorry I got confused ! I re-read your posts and I think I get it now.
I can access the " Set-up Menu " by hitting " 319753 mute " with the generic remote I have, and I can confirm the security setting is set on " low " but this has no influence on accessing SDAM, for which I need the T374AH remote...yes it's all clear now.
In any case thank you very much for your help and patience ! regards
forks is offline
post #10 of 10 Old 04-29-2016, 04:43 AM
razewalk's Avatar
Liked: 0
Originally Posted by forks View Post
<p>I see, sorry I got confused ! I re-read your posts and I think I get it now.</p>
<p>I can access the " Set-up Menu " by hitting " <span style="color:#000000;">319753 mute " with the generic remote I have, and I can confirm the security setting is set on " low " but this has no influence on accessing SDAM, for which I need the</span> T374AH remote...yes it's all clear now.</p>
<p>In any case thank you very much for your help and patience ! regards</p>
Hello - I'm hoping you can shed some light on my problem. A friend purchased a used commercial TV (Philips 42HF7543/37) and I've successfully gotten it out of the commercial mode and hotel mode, with the Anderic RR2573 master remote. I can't control the volume with the volume buttons nor can I change channels with the channel buttons. I AM able to change channels by pushing the "OK" button which brings up a small channel screen and can select a channel by using the cursor buttons surrounding the OK button. So, do I have some setting incorrect? Or, do I need a different remote to control the TV ? Thanks for any light you can shed on this problem!
razewalk is offline
Reply Direct View (single tube) CRT Displays
