Cooling Fan Sony XBR Symptoms - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-24-2014, 03:07 PM - Thread Starter
roamingump's Avatar
My 60" Sony XBR (don't have the exact model number with me but approx. 8 yrs old) goes to black screen, then immediately starts flashing GREEN about 54 times (just under a minute) and the picture comes back. It used to only happen every week or two, not it happens every few minutes. My research indicates that it's the cooling fan and probably not the ballast, but I can't find my symptoms described exactly. When it started, I thought it was the lamp so bought a new one, though not installed yet as the picture does, in fact, come back on within a minute or so. Also, I don't know what they're asking below where it says "Operating System".
roamingump is offline
post #2 of 2 Old 03-24-2014, 04:18 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Wrong forum I do believe, this is the Direct View (single tube) CRT Displays forum.
Floydage is offline
Reply Direct View (single tube) CRT Displays
