Mangled image when using component connection to my Sony Wega - AVS Forum | Home Theater Discussions And Reviews
Old 03-31-2014, 05:09 PM - Thread Starter
rdross80's Avatar
I just bought a Sony Wega KV-32FS320 and hooked up my Wii using the component cables and the image is an absolute mess (picture provided). I tried both component connections on the TV and it's the same. It's not the cables, because I had it hooked up to my HDTV and it looked fine. I've also double checked to make sure the 3 cables were all in the appropriate plugs. The picture is fine with the composite connection. Anyone have any idea what the problem is? IMG_20140331_185515.jpg 3016k .jpg file
rdross80 is offline
Old 03-31-2014, 11:49 PM - Thread Starter
rdross80's Avatar
Nevermind, I think I know what the problem is. The Wii is outputting in progressive and needs switched back to interlaced. I haven't tested it yet, as it means hooking everything back up to my HDTV (which is a bit of a pain), but I'm quite certain that's what is causing the issue.
rdross80 is offline
