How to prevent TVs from going stand-by without signal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-15-2014, 05:25 AM - Thread Starter
marcopiano's Avatar
Hi everyone,
I'm doing an AV performance using some old CRT televisions, making them flicker with audio signal. I'm using SCART plugs for most of them and it works fine, but they automatically go in stand-by mode after a few minutes (5 or so), which is annoying since the piece is some ten minutes long.
Is there any general advice to avoid this? Is there any easily removable clock circuit/component? Or I could get a universal remote to wake them up just before they go stand-by? Other ideas?
Many thanks,
Marco
marcopiano is offline
Reply Direct View (single tube) CRT Displays
