Sony KV-30HS420 Front RCA connector issue - AVS Forum | Home Theater Discussions And Reviews
Old 05-25-2014, 06:34 PM - Thread Starter
Jrgykins's Avatar
I've been having this issue with this TV I recently bought where the front RCA inputs don't work, or at least they display absolutely nothing. I can hear my Dreamcast, which I have plugged in right now, but I can't see anything, it's just pure black. They weird thing is, as soon as unplug the yellow cable, the "VIDEO 2" thing comes back up but it goes away as soon as I plug it in. Any help?
Jrgykins is offline
Old 05-26-2014, 07:20 AM
Ratman's Avatar
Quoted: 1206 Post(s)
Liked: 963
I'll ask the obvious first. Have you tried something else (video) using the front inputs?
Does the Dreamcast system work on a "back" input or another TV?
Ratman is online now
Old 05-26-2014, 01:26 PM - Thread Starter
Jrgykins's Avatar
Yes, the Dreamcast works on other TV's. Just tested the back inputs and they all have the same issue of sound but no picture. Tested them with a Gamecube and a Wii (which both work on other TVs) and still the same issue
Jrgykins is offline
Old 05-26-2014, 01:53 PM
Ratman's Avatar
Liked: 963
Hm-m-m-m... sounds like for some reason, your TV has a problem with "composite" inputs (front and back).
Did the composite input ever work or is this new "second hand" TV that you never tested prior to purchase?
If you can find a way to try S-Video, it may be worth a shot. Other than that... I have nothing more to offer.
Old 05-26-2014, 02:12 PM - Thread Starter
Jrgykins's Avatar
Yes, I might just try buying an S-Video cable and see what happens
Jrgykins is offline
Old 05-26-2014, 02:28 PM
Ratman's Avatar
Liked: 963
Is that "yes" to:
composite used work on this TV but doesn't now
or it's a "used" TV that was never tested prior to purchase and now I'm PO'ed.
Old 05-26-2014, 02:35 PM - Thread Starter
Jrgykins's Avatar
Yes to both S-Video and not testing it and being PO'd :o
Jrgykins is offline
Old 05-26-2014, 03:06 PM
Ratman's Avatar
Liked: 963
Valuable lesson.
Don't get your hopes up though... is composite doesn't work, S-Video may produce the same results. I hope I'm wrong.
Old 05-26-2014, 03:15 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
And hopefully tried a different cable. Looks like the kind of TV that detects an input connection (ex: my Panny detects even if no signal present - like it's mechanically actuated or detects an impedance change).
Floydage is offline
Old 05-26-2014, 06:10 PM
homerging's Avatar
Quoted: 31 Post(s)
S-video picture quality is superior to composite.
homerging is offline
