Help! Philips 20PT Closed Captioning stuck... - AVS Forum | Home Theater Discussions And Reviews
Old 06-07-2014, 06:02 AM - Thread Starter
sonicass's Avatar
The original remote had a dedicated closed captioning button... The universal remote obviously doesn't. My buddy has been watching with captions for two years. Help, pleeeease.
Is there a way to reset the TV to factory defaults?
sonicass is offline
Old 06-07-2014, 07:34 AM
Floydage's Avatar
Quoted: 145 Post(s)
Liked: 64
A lot of u-remotes do so you might try another one. Also check in the system menu for an alternate selection method.
Floydage is offline
Old 06-07-2014, 10:20 AM
Ratman's Avatar
Quoted: 953 Post(s)
Liked: 739
You can probably turn off the CC manually from the front panel.
According to the manual, you can access the adjustment menus by pressing the VOL+ and VOL- simultaneously.
And another thought....
I assume that this TV doesn't have a built-in ATSC or QAM tuner, so therefore you are using an outboard box (cable/satellite?). Check that CC isn't enabled on the box. It may not be the TV. wink.gif
Ratman is online now
Old 06-07-2014, 06:49 PM - Thread Starter
sonicass's Avatar
The menu doesn't have a closed captioning option... I guess I'll have to get a different remote...
sonicass is offline
Old 06-07-2014, 06:50 PM - Thread Starter
sonicass's Avatar
And the cable box cc is off :/
sonicass is offline
Old 06-08-2014, 08:44 AM
Floydage's Avatar
Quoted: 145 Post(s)
Liked: 64
If you haven't already done so, dig around in the menu and see if there is a reset/default function (probably within a system sub-menu). Also look for a small hole on the front panel for a recessed reset button, maybe on the rear but be careful back there.
And did you try Ratman's access method? Maybe it provides a different set of menu functions.
Floydage is offline
taboola here
