PC into Direct View TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-13-2002, 09:31 PM - Thread Starter
hificanuck's Avatar
Hello, I am helping my buddy set up his PC dvd player into his TV. We can get a Windows desktop to show on his Toshiba 24af41c 24" tv but when we load a dvd it will not show on the tv but will play on the laptop. The connection between the tv and pc is of the RCA type.
Could this be a resolution problem?
Any suggestions?
hificanuck is offline
post #2 of 5 Old 07-14-2002, 03:57 PM
DTSChuck's Avatar
Location: In the Theater, at the AV store, on this forum, or asleep
Right click on the computer screen
Go to properties
Go to settings
Go to the advanced button
Click on the “displays†tab
Then you need to make the Tv the “primary deviceâ€
!AND!! you ALSO need to click the button net to the word “monitor†off. The monitor will then flicker to black and all your feed will be displayed on the TV.
Press play and the film will be displayed on the screen but the PC monitor will remain inactive.
That’s exactly how I have done it in the past.
-Chuck
DTSChuck is offline
post #3 of 5 Old 07-16-2002, 10:14 PM - Thread Starter
hificanuck's Avatar
Thanks Chuck, I'll pass this on to my friend.
Alun
post #4 of 5 Old 07-17-2002, 05:07 AM
CO1
CO1's Avatar
Sometimes it may be a setting in the software DVD player. Another problem could be 32 bit color with some DVD players. Try changing it to 16 bit.
CO1 is offline
post #5 of 5 Old 07-17-2002, 08:04 AM
nortac's Avatar
Had the same issue using a laptop. Toggle the <Fn>+<F5> keys on the laptop until only the external monitor is used (laptop screen is off), and you should be all set.
nortac is offline
Closed Thread Direct View (single tube) CRT Displays
