Does component input imply progressive scan? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-15-2002, 01:19 PM - Thread Starter
paranode's Avatar
Hi, I have a Philips 25" TV and it has component(RGB) inputs. I was curious if this meant that it received progressive scan information from these inputs. Like if a DVD player or something else sent it a video signal, would it still be a standard NTSC interlaced signal or a progressive signal? Thanks!
paranode is offline
post #2 of 3 Old 07-15-2002, 01:28 PM
efball's Avatar
Quoted: 66 Post(s)
Liked: 44
Component video signals can be anything 480i, 480p, 720p, 1080i. What your TV will accept is another question. Unless it is a digtial HD ready TV it can only accept 480 interlaced inputs (NTSC).
Vizio M60-C3 UHD TV
Insignia 40" FHD TV
MythTV / Ubuntu / Home Run Prime
Onkyo TX-DS777 receiver
Paradigm Studio v2 speakers
Clark Tactile Transducer
efball is offline
post #3 of 3 Old 07-15-2002, 02:04 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Not exactly... the TV does not have to be "HD ready" to accept/output 480P. 480P is Enhanced Definition TV (EDTV).
So... read the specs, perform a search on the web or provide the model number of the TV and find out what the comp inputs are capable of supporting.
The tuner that is in the set will only do 480I (NTSC).
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Closed Thread Direct View (single tube) CRT Displays
