27inch and component inputs/vs svideo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-18-2002, 10:37 AM - Thread Starter
robertl's Avatar
Will component inputs on 27 inch tvs (around $300-$400) make a big/small/any difference compared to svideo?
i understand that it will on front projectors, and rptv, and probably larger dtv's... but on a fairly small 27 inch?
2.
then off course the natural question :D : Anyone have any suggestion of a good 27 inch dtv for cheap (keyword cheap)
thanks
robertl
robertl is offline
post #2 of 9 Old 07-18-2002, 11:19 AM
DTSChuck's Avatar
Location: In the Theater, at the AV store, on this forum, or asleep
i have a sony 27 inch in the bed room, component inputs make a BIG diff.... S-video will look much worse, you WILL be able to tell
DTSChuck is offline
post #3 of 9 Old 07-18-2002, 12:14 PM
Den
Den's Avatar
I'm a little confused by your question. The cheapest 27" TVs with component input are analog TVs, not "dtv's" (digital TVs); they can display only good ol' fashioned (480 line interlaced) standard definition material, and they have no internal line doubler. Did you want a digital TV, that is, one that can accept and display at least a standard definition digital TV format such as 480p digital broadcast or 480p progressive DVD?
Dennis Rooks
HD Northwest
Den is offline
post #4 of 9 Old 07-18-2002, 12:51 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
I'd say if you're going for a plain old 27" analog TV, component inputs are not a must. With 480I, the difference between S and comp are insignificant.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #5 of 9 Old 07-18-2002, 05:47 PM
BHorn's Avatar
With the keyword being cheap--
Will you be able to tell? Well maybe. Side by side in the store - sure. When you have the set home - maybe not. The difference between composite and svideo is major. Between svideo and component minor.
If you are looking at an inexpensive set I would spend the extra $ on a higher quality set with just svideo. Remember if you use component video you will have to spend some more cash on a good set of cables($30 and up).
If it ends up costing $50 more for a TV with component video and you add in the $30 for cables your $80 in poorer for something which may not really add to your enjoyment. I would take the $80 and either buy a better set or use the $80 for something else.
BHorn
Post Elven Ent
BHorn is offline
post #6 of 9 Old 07-18-2002, 10:35 PM - Thread Starter
robertl's Avatar
gotcha... I understand better now. Component is not a need for me then.
btw, my bad about the dtv.. in haste i wrote that in reference to Direct view TV... tube tvs.. sorry about that.. (i neeeeeed to study the lingo more, know ;) )
robert
robertl is offline
post #7 of 9 Old 07-19-2002, 09:26 AM
mdv
mdv's Avatar
On my now retired 60" Mitsubishi analog RPTV, component inputs made a big difference over svideo.
Mark
mdv is offline
post #8 of 9 Old 07-19-2002, 01:10 PM
WOLVERNOLE's Avatar
Quoted: 105 Post(s)
Liked: 82
mdv-
Well, heck yes...but we were talkin' about a 27" man. :rolleyes:
WOLVERNOLE is offline
post #9 of 9 Old 07-19-2002, 02:39 PM - Thread Starter
robertl's Avatar
mdv - you can send me your retired one :D
this is the el cheapo thread heheh
robertl is offline
Closed Thread Direct View (single tube) CRT Displays
