Which 36" direct view - Panasonic or Toshiba - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-20-2002, 12:29 AM - Thread Starter
ctk74's Avatar
I am looking for my first DTV and would like a 36" direct view. The two models I have narrowed it down to are:
Panasonic CT-36HX42 and
Toshiba 36HF71.
Could someone please offer a constructive opinion on which one has the better features overall? If you had too pick between the 2, which one would you choose and why?
ctk74 is offline
post #2 of 4 Old 07-20-2002, 08:26 AM
wco81's Avatar
Quoted: 1198 Post(s)
Liked: 416
Well for one thing, the Toshiba is probably going to be replaced soon while the Panny is just out. Good Guys had the Toshiba for $1799. What did you see the Panny for?
wco81 is offline
post #3 of 4 Old 07-20-2002, 09:11 AM
jhoppy1's Avatar
Gee .. you should check out the Sony 36XBR-800 (new model) .. I have the 36XBR-500 and love it ... you might find some closeout models for less than $2000 ..... also ... do you plan on watching HDTV or anamorhphic DVD's? if so, you might look into a 34" widescreen (16:9) .. that is the approx viewing size of 16:9 on the 36" 4:3 ... sony and panasonic each make a 16:9 directview HDTV ... you might not like the black bars at the top of a 4:3 TV when viewing widescreen material (doesn't bother me .. I'm used to it ... but my next TV will be 16:9 ... probably a 50" plasma:D )
Jim Hopkins
jhoppy1 is offline
post #4 of 4 Old 07-20-2002, 09:14 AM - Thread Starter
ctk74's Avatar
1799.99 - %10 + 18 months no interest at Best Buy.
ctk74 is offline
Closed Thread Direct View (single tube) CRT Displays
