Sony KV-34XBR800 FAQ - Page 21 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #601 of 622 Old 09-04-2003, 12:16 PM
Ufanco's Avatar
Hi ADU,
Do you have the service manual for the 34xbr800 that was posted on these forum awhile back? If you do look at page 15 there's a list of what each one means. If you don't have the service manual let me know and I will post what each setting is. (RUBW is right upper BOW RUMB is right upper middle BOW).
Ufanco is offline
post #602 of 622 Old 09-04-2003, 04:08 PM
ADU
ADU's Avatar
Quoted: 418 Post(s)
Liked: 658
I think all the good SM links were broken by the time I got here. A manual would take all the adventure out of it anyway. :)
Thanks for the descriptions though. The ...BW, and ...MB corner controls seem to effect the same part of the screen, but in slightly different ways, hence my confusion. I'm sure I'll figure them out eventually though.
ADU
ADU is offline
post #603 of 622 Old 09-04-2003, 07:13 PM
debennett2's Avatar
I have the service manual available if anyone wants to grab i tfrom my FTP. I must warn that it is over 25MB in size and that I only get about 50k/s at most as far as upload speed goes. If anyone needs access, PM me and I'll give them details. Thanks.
Dan Bennett
Learning something new every minute.
debennett2 is offline
post #604 of 622 Old 09-05-2003, 01:51 AM
ADU
ADU's Avatar
Quoted: 418 Post(s)
Liked: 658
I wasn't sure how long my 34xbr800 would be around, so that's why I didn't order a SM before now. It appears I'll be hangin onto it for awhile though, so the investment would probably be justified.
ADU
ADU is offline
post #605 of 622 Old 09-19-2003, 05:54 PM
Thomas F's Avatar
R.I.P.
Thomas
Thomas F is offline
post #606 of 622 Old 10-06-2003, 11:12 PM
artseattle's Avatar
Is there anyway to archive this thread? I don't want to lose it since I come back to occasionally.
Art in Seattle
Art in Seattle
artseattle is offline
post #607 of 622 Old 11-30-2003, 12:36 AM
JoeKing's Avatar
hi, I have the 34XBR800 and used to prefer watching DVDs using Vivid and Standard because of the inky blacks and the very bright image even though a lot of shadow detail was lost. I eventually got fed up and found a way to get the bright clear images that these modes produce and still get the shadow detail I always wanted. Here is what I found.
I set the GAMR GAMG and GAMB to 3 and turned BLK from 3 to 0. This resulted in a washed out image. However, when I toned down the brightness, the blacks were very deep, the image was bright, and most importantly, shadow detail was greatly improved.
On a side note, the Vivid and Standard modes seem to have a "bluer" hue regardless of what the color temperature is set to. I actually think that Vivid set to WARM is a great compromise because you get whites that don't have a brown tinge to them and they are not noticably blue either.
also, here are my settings....
DRC "sharpness" is set to 15 and "smoothness" is set to 0
I use interlaced on most movies. Cinemotion on movies that exibit a stairstepping type effect.
I hope this information is useful for other people as picky as I am.
JoeKing is offline
post #608 of 622 Old 11-30-2003, 11:52 AM
debennett2's Avatar
Too bad there wasn;t a way to take a pciture and compare settings.
Dan Bennett
post #609 of 622 Old 12-01-2003, 05:54 AM
Calabs's Avatar
Has anyone figured out what codes to use for Zenith satellite receivers. I've got the SAT520 and the Sony manual does not have codes for Zenith. Had anyone asked this question to Sony?
Any help is appreciated.
Calabs is offline
post #610 of 622 Old 12-01-2003, 08:47 AM
debennett2's Avatar
Codes to do what?
Dan Bennett
post #611 of 622 Old 12-01-2003, 09:52 AM
Calabs's Avatar
Sorry for not be more clear. I want the Sony remote to operate my Zenith SAT520. The code I was referring to was the code number(s) Sony uses to perfer that task. In the manual, they include many codes for satellite receivers, but non for Zenith.
Is that clear now?
Calabs is offline
post #612 of 622 Old 12-02-2003, 10:10 PM
ADU
ADU's Avatar
Quoted: 418 Post(s)
Liked: 658
Yep. But I don't know the answer. Maybe somone else does though.
Very interesting, Joe.
Internal reflections/black retention are still proving to be a minor problem on my set, so I'm curious to hear any any ideas along these lines.
ADU
ADU is offline
post #613 of 622 Old 12-03-2003, 06:00 PM
JoeKing's Avatar
ADU: I used to have a huge problem with black level retention on Sony direct views but have now solved it.
I have a Panasonic RP-91 and I have heard that most Panasonic DVD players have an option of turning the black level to brighter or darker.... when I set my DVD player to lighter I didn't have to put my TV's brightness too high and I saw a notable improvement in black level retention. With the DVD player set to darker, I had to push the brightness a couple of notches above the midpoint and I got annoying glowing when watching bright scenes.
I used to have my TV set to MOVIE and pushed the contrast slightly harder that I would have liked in order to subdue when I believed to be a brownish tinge on white objects. With this setting my TV suffered when it came to black level retention as well.
I know that if you can handle watching movies with the color temperature on Neutral, you can tone the contrast down a lot and still get a bright image and the set will hold black at black a bit better.... I however, can not stand watching movies on Neutral and have found a great middle ground.
I have my TV set up to what I posted earlier and the black level retention is a great deal better now. On VIVID or STANDARD, there is a slightly bluish tinge to the whites but VERY slight.... so when I set my TV to STANDARD, did the service menu tweaks, and adjusted my contrast/brightness with my VE disk, the contrast/brightness were only slightly higher than 1/3 yet I got an extremely bright image(that is satisfying to watch in the daytime) and I didn't have to deal with brownish looking whites.
on a side note.... I have Belden 1694 cables and when comparing them to the monster cables I was using for temp, the beldens boosted the brightness. Because of this, I had to drop my set's brightness a couple of clicks.... this could have helped with my set's black level retention as well.
btw, I have three settings for DVD right now since that is my focus for this set at the moment....
I have vivid set up to how I described in my earlier post and I use that for all DVDs that are not film based(monster's inc, ice age) or movies that have little edge enhancement. Vivid has a very small amount of added edge enhancement when compared to the Standard mode but the image does seem to pop out at me more.
I have standard set up according to my earlier post as well and use that for almost all of my DVDs.
There was only one movie where I felt that I needed to switch from my STANDARD setting to MOVIE. When I was watching Pirates of the Caribean, I felt that I gained a slight amount of shadow detail that I didn't even know was there. Here is how I tweaked my MOVIE setting in case somebody is interested. I kept the GAMMA SM adjustments for movie the same but adjusted the MID5 SM adjustments so that they matched VIVID. That way I got an image that I felt was pure and not blurred in any way. Maybe some people would prefer matching MOVIE's MID5 settings to Standard. I chose VIVID because I felt the edge enhancement was harder to identify given that the white and black parts of the image are not varied as much as in the VIVID and STANDARD modes.
I hope that this information helps. Also, if anybody tries my techniques I would be happy to hear what they think of them.
JoeKing is offline
post #614 of 622 Old 12-04-2003, 12:24 AM
JoeKing's Avatar
I have a possible solution for people who are seeing trails/smearing during dark scenes with bright objects. I have heard "Y delay" causes what appears to be a smearing effect when viewing movies. Today when I went through my TVs service menu I noticed a setting called YDLY, chose Blade 2(which showed trails during the opening scene) from my DVD collection, replayed a scene with trails, toggled through the values and found that 1 appeared to fix the trails to some degree for me. I will admit that I am not extremely knowledgable when it comes to fixing this type of problem but what I did seemed to tone down what I was seeing and I thought I would share.
Also, I guess that only some TVs have this problem and not all and that every set is different when it comes to this problem and that is why I think the value is set to 0 from default.
just my 2 cents
JoeKing is offline
post #615 of 622 Old 12-04-2003, 12:54 AM
ADU
ADU's Avatar
Quoted: 418 Post(s)
Liked: 658
Very interesting ideas, Joe. Thanks for posting. Since I'm using an HTPC and can do a fair amount of gamma/brightness tweaking with that, I've been a little lazy with this stuff in the TV's service menu. I think there may still be some room for improvement there as well though.
Also, I have the same question as coldpiece about making my set hold blacks as well as possible because when looking at anamorphic films there is some blooming seen through the letterbox that really bothers me.
This is the kind of thing I'm talking about re internal reflections and black retention. When you're watching a fairly bright scene on a 2.35AR movie, the black bars and other black details in the image get washed out. I think the TV should be able to hold the blacks a little more strongly.
ADU
ADU is offline
post #616 of 622 Old 02-17-2004, 08:56 PM
shpankey's Avatar
Liked: 35
most of the links in the first post are now dead btw
26 What good will it be for a man if he gains the whole world, yet forfeits his soul? Or what can a man give in exchange for his soul?
Matthew 16:26 NIV
shpankey is offline
post #617 of 622 Old 02-17-2004, 11:20 PM
artseattle's Avatar
Just click on the links in the first post and then replace the letters www with "archive" This will bring you to the old messages.
Art in Seattle
post #618 of 622 Old 02-18-2004, 03:46 PM - Thread Starter
ricbayer's Avatar
Thank you Art. I am still really happy with my choice of the 34xbr800 back in August 2002. My wife and I watch DVDs almost every night and they look great even with S video in from my several year old DVD player.
I read the forum weekly esp the DVD player part in case my player refuses to spin someday. Thanks again to AVS forum for helping me make the right choice with my 34xbr800. :)
Rick
ricbayer is offline
post #619 of 622 Old 02-18-2004, 06:29 PM
ADU
ADU's Avatar
Quoted: 418 Post(s)
Liked: 658
What? No desire to trade up to something with a finer dot pitch, etc.? Where's your competitive spirit man? :)
FWIW, after about a year and half of work, I've almost got my 34xbr800 lookin the way I want. (Grey scale and convergence helped alot.) At this rate, I should be finished just about the time the Star Wars Trilogy comes out. So I'm still open to suggestions. :)
ADU
ADU is offline
post #620 of 622 Old 02-18-2004, 06:59 PM
debennett2's Avatar
Can someone point me to the vertical bar fix? I applied it awhile ago and then tried reverting back but not sure if I got everything. HD just doesn;t quite have all the oomph it had before...still great, don;t get me wrong. Thanks.
Dan Bennett
post #621 of 622 Old 02-18-2004, 07:33 PM
ADU
ADU's Avatar
Quoted: 418 Post(s)
Liked: 658
ADU is offline
post #622 of 622 Old 02-28-2004, 02:43 PM
ADU
ADU's Avatar
Quoted: 418 Post(s)
Liked: 658
FWIW, my thinking re how to approach these issues on TVs like the 34XBR800 has evolved a bit. So I revised Post #557 here re Gamma to bring it more in line with this. And for the record, here a few excerpts from some other recent threads.
From a Thread on the Hulk DVD
With the exception of the slight EE, this is a pretty nice lookin DVD. IMO, one of the reasons for this is strong gamma undercorrection. Midtones are made deliberately darker so the image has more depth and richness when viewed in a dark theater style setting...
This has some pretty dark scenes in it though, so if you watch this in a setting with more ambient light, the midtones may seem rather dark and detail may be a strain to make out in the shadows. (This is the way it seemed to me on a direct-view CRT with only a modest amount of ambient light.) Even if you max out the contrast on the TV, in such a setting, it still may not provide enough gain to see much shadow detail [and may have other negative consequences on PQ]. There are a couple different approachs to compensate for this. If you're using an HTPC, you could raise the gamma or white level (picture/contrast) in the player or overlay. Or you could use the Enhanced (Vivid, Standard) modes on the TV or DVD player, which will do much the same thing. Boosting the white level on the DVD player or HTPC will provide more contrast and shadow detail at the expense of bleaching out some of the highlights (skys especially). Boosting gamma will make shadow detail more visible at the expense of some richness and depth. These are the sort of things that may be necessary though to get this to be comfortable/enjoyable to watch on a CRT if you can't decrease the ambient light or don't want to boost the contrast on the TV (to protect the phosphors from excessive wear).
As DVDs are better produced for HT, I find myself wanting to decrease the ambient light in my viewing environment more and more (a few 15 watt bulbs seemed ample for this DVD...). If you go too dark though, then motion artifacts (phosphor decay) may start to become a bit more noticeable (always tradeoffs, aren't there :) ). This is really enjoyable to watch with the right settings and conditions though. The Hulk looks very... Hulky.
Anyway, just to review, if you're having difficulty making out shadow details on somethin like this and don't want to sacrifice solid blacks, some things you could try are...
1) decrease the ambient light in the viewing environment
2) increase the contrast on the display
If these aren't workable/preferable, then...
3) boost gamma or use enhanced/vivid modes on display.
4) boost gamma or contrast/white level, or use enhanced vivid modes on DVD player/HTPC.
From the XBR910 FAQ
Some ideas re basic PQ adjustment prior to calibration...
Most of the default settings in the different picture modes are tuned for a satisfactory picture out of the box. Movie may a good choice for night-time viewing because it has decent, but not excessive black retention, clarity and no gamma enhancement. For daytime viewing Standard mode may be a little easier to watch, due to its brighter midtones (gamma). Color temp is probably a matter of personal choice at this point. Warm is supposed to be closest to NTSC's normal temp, but the color bias on the TV may be so strong/inaccurate that it makes little difference at this stage (FWIW, Neutral was my initial preference on the 34xbr800 too). You can use the THX Optimizer on any THX mastered DVD to fine-tune a few settings like Brightness, Color Saturation, etc a bit more. You may want to dial the Color saturation back a bit to compensate for red push.
I generally recommend DRC Cinemotion for the 480i up-conversion, this has cadence-based reverse-telecine so it ought to give you the best up-conversion of film-based content to 480p. On video-based content, the DRC Interlaced option (which I believe simply doubles the lines to 960i) may also be worth a try. Cinemotion may adjust it's de-interlacing dynamically depending on the content though, but I think it will always up-convert to 480p.
I don't really recommend changing the Picture/Contrast settings on the TV until you're ready to dig into the calibration a bit more. Adjusting the ambient light in your viewing environment and viewing distance until you can see the picture well may be a better strategy instead. Don't watch the TV in total darkness though. Leave at least a couple dim lights on. (I use a few 15 Watt bulbs, FWIW)
If you do change the Picture setting (white level), then adjust the Brightness (black level) again afterward because this may tend to drift based on how high Contrast/Picture is set.
More from the XBR910 FAQ
Time to start exploring some of the calibration links I guess, and maybe try out DVE or AVIA. My suggestion re leaving the Picture/contrast at the default is more a guideline for initial viewing than a steadfast rule btw. Out of the box, most of the settings in the TV will be tuned for the default contrast settings in the User Menu. To effectively go outside this default paradigm, you'll probably need something a little more robust than just the THX Optimizer.
In the meantime, here a few basic things you could try.
1) If you can lower the ambient light in your viewing area a little more without phosphor trails and internal reflections becoming a distraction, that may be worth a try and may help in seeing shadow detail.
2) How far are you sitting from the TV? If you're too far away, their may not be enough contrast to see the picture well in the TV's default configuration. (FWIW, the Vivid and Standard modes may be a little easier to watch from a greater distance due to their enhanced gamma and blacks.)
3) If you're using a DVD player, see if it has any adjustments for gamma or contrast, or Vivid modes of it's own it. Adjusting these can help make darker DVDs easier to watch.
4) Movie mode does have slightly enhanced blacks, so it may be too dark for some content which is heavily gamma undercorrected. Pro or Standard mode may work a little better in such cases.
As I was mentioning in the Too Much Black thread, grey scale adjustment did seem to improve the shadow detail on my TV. Adjusting the RGB Cutoffs more accurately seems to give a better blend of colors near the dark and light ends of the color spectrum, improving detail in those areas. To get there though you do have to take the TV out if it's factory signature color configuration, which isn't everyone's cup of tea. The grey scale and color decoder/saturation adjustments will make colors more well-defined, differentiated and subtle, as opposed to the strong reds and blues on the TV now (green is a lovely color too Sony ).
Another thing you could do in the meantime is just keep Brightness a little higher than normal, though this may make the picture a little washed out.
6-8 feet is a little far IMO for this TV. It might be a little easier to watch around 4.5-5 feet, particularly given the slightly dimmer picture. YMMV though.
From a Thread on XBR910 Black Levels/Calibration
1. The black level on the Sonys may tend to drift depending on how high the contrast is set. So if you change the Picture/contrast setting, you'll most likely need to re-adjust Brightness as well to compensate.
2. Regular NTSC sources may have a 7.5-IRE black level, while many DVD players use a 0-IRE black level. If the Brightness on your TV is adjusted for a 7.5-IRE black level, then the blacks will be crushed when viewing a 0-IRE source. Brightness needs to be set higher for 0-IRE sources than 7.5-IRE sources. If you have not made adjustments for this in the service menu (per NTN1's remarks for example), then you may need two User Menu Brightness settings to get decent blacks from all your video sources.
3. Blacks (and whites for that matter) will tend to look alot muddier if the grey scale on the TV is not well adjusted. If red, green and blue are not clipped or cut off at the same levels, then they will not blend together well enough to give good definition in the darker colors. Shadow detail improved noticeably on my 34xbr800 after the color balance and grey scales were better adjusted. This means undoing Sony's signature color bias though.
4. Many recent DVD titles, including the Hulk, may have strongly undercorrected gamma, which can make their midtones quite a bit darker than other video sources. This is probably done to give them a more dynamic appearance on high-contrast displays with no ambient lighting in the room. However, it's just the opposite of what you need on a display with rather weak contrast like the 910 with even moderate ambient lighting, and makes the picture very murky and difficult to watch. There are a variety of ways to compensate for this. Using the Standard and Vivid picture modes on the TV is one approach. These modes have boosted gamma, enhanced blacks, and slightly punched highlights which are designed to combat the weak contrast on the TV and undercorrection on DVDs to make the picture more watchable. Another and possibly better option is a DVD player with a good variable gamma adjustment. A variable gamma control on the player will allow you to raise and the lower the brightness of the midtones (and hence shadow detail) with greater control to compensate for different types of content and viewing conditions... without having to fiddle with settings on the TV, and without crushing or clipping the ends of the color palette. This can be particularly handy if you watch TV in a room without controlled lighting.
It's also possible to adjust gamma (upward anyway) on the TV itself via the SM as shpankey mentions here for example.
ADU
ADU is offline
Closed Thread Direct View (single tube) CRT Displays
