kv-34xbr910 with no hdmi only dvi connecting a ps4 how? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-10-2015, 02:54 PM - Thread Starter
pctek's Avatar
i got a kv-34xbr910 super fine pitch tv with dvi port for free from my customer, so if I kep it and use it how would I connect a ps4 to it since ps4 only uses hdmi? Anyone know of a dvi to hdmi with audio setup?
pctek is offline
post #2 of 3 Old 10-11-2015, 11:03 AM
Floydage's Avatar
Quoted: 158 Post(s)
Liked: 69
HDMI to DVI cable or adapter. Have to send the audio separately.
There's this:
"...a DVI display that lacks optional support for HDCP might be unable to display protected content even though it is otherwise compatible with the HDMI source. Features specific to HDMI such as remote control, audio transport, xvYCC and deep color are not usable in devices that support only DVI signals. HDCP compatibility between source and destination devices is subject to manufacturer specifications for each device."
but the Wiki Trinitron-WEGA page claims this model's DVI as HDCP-compliant.
Floydage is offline
post #3 of 3 Old 04-10-2016, 02:30 PM
CRTGAMER's Avatar
There's this:
THIS. I connect my BluRay and Cable Box thru the DVI port with a simple HDMI to DVI adapter on my HD CRT WEGA. The audio is fed thru the analog audio RCA input jacks.
CRTGAMER is offline
Reply Direct View (single tube) CRT Displays
