Building a DisplayPort/DVI/HDMI to VGA Adapter - AVS Forum | Home Theater Discussions And Reviews
Old 06-10-2016, 07:07 PM - Thread Starter
superchad's Avatar
Wanting to make an Adapter to keep using my secondary monitor, a CRT at 1920x1440@75Hz
Is anyone hear familiar enough with ICs to make such an adapter?
RAMDAC would be an ADV7123 330MHz 10-bit RAMDAC.
I need a device which can accept GTF timings and drive the RAMDAC, options are:
1. ADV7619, which would require interleaving of or combining of the dual 24-bit busses (odd and even pixels)
2. STDP4020 hooked up (no idea how to, can't find detailed data sheets.)
not sure on how to hook up the ADV7619, I don't know how i can Interleave or Combine, and even if i could i have no idea how to hook up composite sync and blank signals to the ADV7123
this thread here may provide a bit of info that could be useful.
https://ez.analog.com/thread/46833
obviously if i need other ICs that is fine, just need to know what to drive the ADV7123 with, and what else is needed.
anyone know enough to help? this would allow up to 1920x1440@81-82Hz for a CRT Monitor, with the ADV7619 i know it could only do 8-bits per pixel, but better than nothing.
superchad is offline
Old 06-11-2016, 10:37 AM - Thread Starter
superchad's Avatar
I found a datasheet for the STDP4020 maybe this could help with wiring it up, looks like it contains similar outputs to the ADV7169
http://media.digikey.com/pdf/Data%20...20_4010_DS.pdf
it also provides the HS, VS, DE (Data Enable), and CLK that the ADV7169 provides, but appears to support a higher pixel clock
from the datasheet
"The 60-bit LVTTL output ports can be mapped to
transfer video data either in two pixels per clock or single pixel per clock up to 330 MHz pixel rate"
it also has odd and even channels for color data
does it only use half of them if in single pixel per clock mode? so i can just wire up the two devices? or does it send pixels alternating and need to be interleaved like the ADV7169 does?
after figuring that out what do i have to do for NBLANK and NSYNC for the ADV7123? is this the DE pin? the clock? or something else, if something else what is it?
