Sony KV32HS510 and the DVI connector... - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2003, 12:45 PM - Thread Starter
Shok's Avatar
Has anyone tried to connect a computer to the DVI connector on the Sony KV-32HS510 ? I have a DVI to VGA adapter and I was wondering what would happen if I try to connect a PC using the adapter, can I damage the TV ?
Thanks for any help
Shok is offline
Old 09-30-2003, 12:54 AM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 520
FWIW, there's alot of info/links re DVI in the Computer Input and some other threads in my signature.
I'm not sure what kind of DVI/VGA adapter you're referring to though. What sort of video card do you have on your computer, and what kind of video ports are on it? And how is the adapter designed to attach to it?
ADU
ADU is offline
Old 09-30-2003, 08:06 AM - Thread Starter
Shok's Avatar
Thanks for your help. It was an Apple DVI-to-VGA adapter, I borrowed one from work yesterday, but the DVI connector on the TV is slightly different than the adapter I got; the shape of the connector is the same, but the pins are different, the connector on the TV is missing some of the extra pins in the adapter.
I wanted it to use the adapter to connect my Sega Dreamcast through the VGA port, but I guess I need to look into another way to do it.
Shok is offline
Old 09-30-2003, 11:06 AM
ADU
ADU's Avatar
Quoted: 313 Post(s)
Liked: 520
I'm still a bit unclear on what's going on. But if you're coming from the VGA output on a PC or game machine, that signal would be analog RGB. The TV however is designed for EIA-861 (HDTV) digital RGB.
The adapter sounds like it was designed to convert a DVI-I MAC output (which would include both digital and analog RGB signals) to analog VGA for input on an analog VGA monitor, which wouldn't really help you.
Converting an analog VGA output to digital DVI is probably an expensive proposition, and not worth the trouble. I'm not very savvy about games. but if your game machine doesn't have YPbPr Component output, then you might be able to use a VGA -> YPbPr transcoder to run the VGA signal into the TV's YPbPr component inputs.
ADU
ADU is offline
