Zenith C32V37 Settings (Standard and Service Menu) - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 405 Old 02-27-2004, 01:09 PM - Thread Starter
dman78's Avatar
Here is a place to post and discuss any settings related to the Zenith C32V37. This includes both standard picture settings (brightness, color, contrast, etc.) and settings from within the service menu. Also, feel free to discuss the service menu in general. My TV isn't getting delivered until Sunday, so I'll get my settings up as soon as I have them. For now, I'll get this started with a couple of good posts from the >>> Zenith C32V37 with integrated HDTV tuner - mini review <<< thread.
dman78 is offline
post #2 of 405 Old 02-27-2004, 01:10 PM - Thread Starter
dman78's Avatar
Originally posted by shroomus
OFA stands for One-For-All, it's a particular brand of universal remote that Radio Shack resells. It has a nifty feature where you can send discrete codes by number, and program arbitrary discrete codes to keys.
The four-digit TV code is 0178 as previously mentioned (Proton TV remote code, I think) and the discrete code that gets you into the service menu is 018.
I don't know if you can use the Zenith remote to get into the service menu, I doubt it.
Custom settings I used -- note that I don't have any real calibration DVDs or anything, so take with a grain of salt:
Raster,Center,H/V_Size
1. V-Position 27 -> 30 (note: big changes here tilt everything)
2. V-Size 29 -> 20 (eliminates nearly all overscan)
3. H-Position 36 -> 32
4. H-Size 52 -> 40 (eliminates nearly all overscan; note: values too small cause pincushion???)
5. UP-VLIN 0
6. LO-VLIN 0
7. Pin_Amp 39
8. Pin_Phase 29
9. Up_CPin 40
10. Lo-CPin 41
11. AFC-Bow 31
12. AFC-Angle 30
White-Balance
1. R-DRIVE 38 -> 31 (trying to reduce red push)
2. G-DRIVE 31
3. B-DRIVE 36
4. R-CUT 37 -> 31 (trying to reduce red push)
5. G-CUT 31
6. B-CUT 40
dman78 is offline
post #3 of 405 Old 02-27-2004, 01:13 PM - Thread Starter
dman78's Avatar
Originally posted by qqqqq
Sorry for the delayed response.
Here's the list of discrete codes I have. It's not complete and may have some errors. Shroomus I thought it was 014 that caused the reset to default, but I may have been clicking too fast and didn't notice it. I don't want to try again to check.
AR = Aspect Ratio
SM = Service menu
009 AR - Set by Program
012 SM - Picture Check
014 SM - Reset to Defaults *****DANGER ******
015 SM - Reset to Defaults *****DANGER ****** ???
016 SM - Sound Check
017 SM - Tilt
018 SM - EZ-Adjust Menu
019 SM - In-Start Service Menu
025 Caption Setting
034 Input - Component 1
040 Picture Menu
053 Power
054 Sleep Timer
055 Audio Button (Caption Lang)
057 Mute
059 Input - TV, Video Cycle Button
079 Digit ? Or Channel Diplay
095 Info
098 AR - Zoom
103 Sound Menu
108 Input - Component 2
109 Input - Video 2
110 CATV
111 Input - Front Video
113 Input - Video 3
116 Digit 4
117 Digit 0
118 Digit 6
119 Digit 2
120 Digit 5
121 Digit 1
121 Input - DTV
122 Digit 7
123 Digit 3
126 DTV Signal Strength
133 PiP related
134 AR - 4:3
135 PiP related
137 PiP related
138 AR - 16:9
164 Digit ? Or Channel Diplay
167 Menu
171 Menu
173 Ch +
174 Input - DVI
175 Vol +
176 Off
177 Ch -
178 Input - TV, Video Cycle Button
179 Vol -
181 Ch +
183 Vol +
185 Ch -
187 Vol -
197 PiP related
200 Freeze frame
201 PiP related
203 PiP related
231 Input - Video 1
232 Input - Component 1,2, DVI toggle
245 Digit ? Or Channel Diplay
246 Surf
247 Last
253 Input - Component 1
dman78 is offline
post #4 of 405 Old 02-27-2004, 01:13 PM - Thread Starter
dman78's Avatar
Here's what I have for the OFA...
Non-LCD remote instructions:
A. To test a code:
# Press the device key
# Press SETUP (don't hold it)
# Enter the 3 digit code
# Check for a response from your equipment
# (Holding the final digit down is the same as holding the actual button down)
B. To program a code:
# Press and hold SETUP (wait for two blinks)
# Enter 9-9-4 (wait for two blinks)
# (Optional) Press the device button the code is coming from
# (Optional) Press the device button the code is going to
# Press the button to be assigned
C. To program a code (to a SHIFT key):
D. To delete a code:
# Press the assigned button - twice
E. To delete a code (from a SHIFT key):
So, to send 018 you would make sure you're in TV mode first, then press and release Setup, then type 018.
Here's my list of discrete codes, between this and the other post I can't imagine what we'd have missed:
012
P-CHECK (Factory Mode)
1.CONTRAST: 25
2.BRIGHTNESS: 50
3.COLOR: 50
4.TINT: 0
5.SHARPNESS: 50
(exit this mode by hitting MENU)
014
discrete code for TV? went to channel 13?
maybe switching between antenna and cable?
015
factory reset??? turned audio back on!
016
S-CHECK (Factory Mode)
1.VOLUME: 0
2.BALANCE: 0
017
tilt adjustment
018
Ez Adjust
1. Raster,center,H/V_Size ->
2. Pin-Cushion
3. Cut-off
4. White-Balance
5. Sub-Bright
6. Sub-Tint/Color
7. White-Pattern
8. DVCO-Set
9. AD9883A-Set
10. VPX3226
019
IN-START
1. CXA2150AQ ->
2. CXA1875AM
3. UPD64083
4. AD9883A
5. AD9883A_NVRAM
6. HD2-Chip
Cpu Ver: 32V 3.03.1
Mic Ver: 01.10
025
caption toggle
034
discrete code for Component 1
036
number 2 key
040
video setting toggle
053
power toggle
054
sleep timer toggle
055
audio mono/stereo/SAP selection
057
mute toggle
059
video source toggle
079
brings up just the little upper right box, but not the info button?
095
info
098
This feature is not available now -- ?
103
audio preset toggle
105
discrete code for Front Video
108
discrete code for Component 2
109
discrete code for Video 2
110
111
discrete code for Front Video?
113
discrete code for Video 3?
116
number 4 key
117
number 0 key
118
number 6 key
119
number 2 key?
120
number 5 key
121
number 1 key
122
number 7 key
123
number 3 key
126
signal strength
133
discrete code for second PIP (scan) mode
134
discrete code for 4:3 aspect ratio
135
pipch - (This feature is not available now -- ?)
137
pipch + (This feature is not available now -- ?)
138
discrete code for 16:9 aspect ratio
164
Enter (brings up just the little upper right box, and a time display lower right?)
165
up arrow
167
menu
169
down arrow (when in menu, discrete code for time category)
171
menu
173
ch +
174
discrete code for DVI
175
vol +
176
discrete code for power off
177
ch -
178
video source toggle
179
vol -
180
up arrow
181
ch +
182
right arrow
183
vol +
184
down arrow
185
ch -
186
left arrow
187
vol -
197
PIP mode toggle
200
freeze
201
PIP input toggle
203
PIP swap
210
231
discrete code for Video 1
232
component/DVI source toggle
235
exit
245
number 8 key
246
surf
247
flashback/recall
249
number 9 key
253
And here are my original service menu settings (well, after 015 :-):
1. Raster,Center,H/V_Size ->
1. V-Position 27
2. V-Size 29
3. H-Position 36
4. H-Size 52
5. UP-VLIN 0
6. LO-VLIN 0
7. Pin_Amp 39
8. Pin_Phase 29
9. Up_CPin 40
10. Lo-CPin 41
11. AFC-Bow 31
12. AFC-Angle 30
same menu for 2. Pin-Cushion
no choices under 3. Cut-off
4. White-Balance ->
White-Balance
1. R-DRIVE 38
2. G-DRIVE 31
3. B-DRIVE 36
4. R-CUT 37
5. G-CUT 31
6. B-CUT 40
5. Sub-Bright ->
Sub-Bright
1. SUB_Bright 21
6. Sub-Tint/Color -> (warning -- tint changed on entry!)
Sub-Tint/Color
1. SUB_TINT 12
2. SUB_COLOR 19
no choices under 7. White-Pattern
no choices under 8. DVCO_Set
9. AD9883A_Set ->
AD9883A: Failed! 'CHECK INPUT IMAGE'
10. VPX3226 ->
VPX3226
Contrast(m) 31
Contrast(s) 31
You've already seen my custom settings, but just for completeness:
Custom settings:
5. UP-VLIN 0
6. LO-VLIN 0
7. Pin_Amp 39
8. Pin_Phase 29
9. Up_CPin 40
10. Lo-CPin 41
11. AFC-Bow 31
12. AFC-Angle 30
White-Balance
2. G-DRIVE 31
3. B-DRIVE 36
5. G-CUT 31
6. B-CUT 40
dman78 is offline
post #5 of 405 Old 02-27-2004, 08:38 PM
Q of BanditZ's Avatar
Heck, I am so happy with it I don't even think I'll need to fool with all this! I might buy DVE and call it a day! :)
Great ISF Job by Chad B.
Q of BanditZ is offline
post #6 of 405 Old 02-27-2004, 11:19 PM
kevlo9's Avatar
THANKS!
This is a VERY useful thread!
posted mine and they are somewhere in this thread i think a page back
Contrast: 51 (high 40s is good)
Brightness:61 (60 is borderline)
Color:40 (you can go as low as 35 still looks great)
Sharpness: 39
Tint: R1
Color Temperator: Cool
Z View: On
And in Option I have tilt at +3
note: Color Saturation and Tint was a little itty bitty off in Service menus
You can set a Blue,Red or Green Filter in service menu 019 code, 018 code is for Over the air only!!!!
What is the difference in color temp. settings? Every setup dvd that I've used always says to set your tv to the warmest setting? Do picture settings differ with the different color temps? Also what does Z VIEW do? I did notice that the picture looked better with it on.
Thanks again.
kevlo9 is offline
post #7 of 405 Old 02-28-2004, 11:43 AM
Not sure what it is, but I always have Z view on and I look the cool color temperature to keep those reds under control.
I can endorse Bremerton's settings here, except I didn't feel the need to go into the service menu, and I like the sharpness in the mid 50's.
post #8 of 405 Old 02-28-2004, 01:32 PM
hdphil's Avatar
here is some values from service menu 019.
it's not complete yet,cut and paste in notebook, put your own values so you can save b4 tweaking.
descrete code 019
1. cxa2150aq
1. pic_on 1
2 R_ON 1
3 G_ON 1
4. B_ON 1
5. DCOL 0
6. WB_SW 0
7. GAMMA_L 0
8. PICTURE 63
9. BLK_BTM 2
10. HUE 32
11. COL_AXIS 2
12. COLOR 38
13. CTI_LEV 1
14. BRITE 21 33 (hdtv)
15. S_ABL 0
16. SHARPNESS 52
17. LTI_LEV 1
18. R_DRIVE 19
19. PLIMIT_LEV 0
20. G_DRIVE 16
21. ABL_MODE 2
22. B_DRIVE 29
23. CTI_MODE 0
24. SUB_BRITE 21
25. GAMMA 1
26. R_CUTOFF 15
27. LTI_MODE 1
28. G_CUTOFF 15
29. DPIC_LEV 2
30. B_CUTOFF 22
31. DC_TRAN 3
32. SUB_CONT 3
33. LRGB2_LEV 0
34. SUB_COL 20
35. SUB_TINT 12
36. P_ABL 8
37. ABL_TH 4
38. CB_OFFSET 31
39. AGING_W 0
40. AGING_B 0
41. CR_OFFSET 31
42. SYSTEM 2
43. Y_OFFSET 7
44. VM_LEV 2
45. SHP_FO 0
46. CD_OFF 0
47. SHP_CD 0
48. SHP_F1 0
49. PRE_OVER 0
50. VM_COR 3
51. VM_FO 2
52. VM_LMT 3
53. VM_DLY 3
54. AKBTIM 12
55. BLK_OFF 0
56. AKBOFF 0
57. UP_BLK 2
58. LO_BLK 5
59. V_SIZE 43
60. V_ON 1
61. EW_DC 0
62. V_POSITION 36
63. VSAWO_DCH 0
64. V_LIN 7
65. S_CORRECTION 2
66. H_SIZE 42
67. UP_UCP 0
68. PIN_AMP 35
69. LO_UCP 0
70. UP_CPIN 40
71. UP_UCG 1
72. LO_CPIN 41
73. LO_UCG 1
74. PIN_PHASE 32
75. UP_POL 0
76. VBLK_SW 0
77. H_POSITION 28
78. CLP_SHIFT 0
79. SYNC_PHASE 0
80. AFC_BOW 31
81. AFC_MODE 2
82. AFC_ANGLE 26
83. RST_SW 1
84. LEF_BLK 42
85. CLP_PHASE 3
86. RIGHT_BLK 20
87. CLP_GATE 0
88. HBLK_SW 1
89. V_ASPECT 31
90. ZOOM_SW 0
91. JMP_SW 0
92. V_SCROLL 28
93. VFREQ 1
94. UP_VLIN 4
95. LO_VLIN 1
96. V_COMP 5
97. H_COMP 5
98. VSAWO_DCL 0
99. VSAW1_DC 0
100. VSAW0_AMP 0
101. PIN_COMP 5
102. VSAW1_AMP 0
103. AFC_COMP 0
104. MP_PARA_DC 0
105. MP_PARA_AMP 0
106. HC_PARA_DC 57
107. ASP_SW 0
108. VDRV_SW 0
109. HC_PARA_AMP 45
110. HC_PARA_PHASE 31
CXA1875AM
1. REF 0
2. SW3 1
3. SW2 1
4. TILT1 1
5. TILT2 0
6. DFGAIN 60
7. DF PHASE 120
8. DAC2 0
9. TILT CTR 0
10. CS CTR 48
UPD64083
1. YAPS 3
2. COUTS 3
3. NRMD 0
4.KILS 1
5. MSS 0
6. NSDS 0
7. CLKS 0
8. EXCSS 1
9. PECS 0
10. MFREEZE 0
11. EXADINS 0
12. DYCOS 2
13. CDL 4
14. HDP 4
15. CPP 0
16. DYGAIN 9
17. DYCOR 2
18. DCGAIN 6
19. DCCOR 3
20. CNRLIM 1
21. CNRINV 0
22. CNRK 0
23. YNRLIM 1
24. YNRINV 0
25. YNRK 0
26. STOS 1
27. STIS 0
28. CL8OFF 1
29. ID1WOA2 0
30. ID1WOA1 0
31. ID1ON 0
32. LDSR 2
33. VTRR 1
34. VTRH 1
35. WSC 1
36. TT 0
37. FELCHK 1
38. TH 0
39. ID1DECON 1
40. WSS 0
41. VAPINV 10
42. VAPGAIN 2
43. YPFG 13
44. YPFT 2
45. SELD2FH 0
46. CLPH 0
47. COHS 0
48. CC3N 0
49. VEGS 2
50. V1PS 2
51. SELD1FL 0
52. KCTT 0
53. CSHDT 0
54. OVST 0
55. ED2OFF 1
56. YHCGAIN 0
57. YHCOR 1
58. CLKGT 0
59. CLKGEB 0
60. CLKGGT 0
61. CLKG2D 1
62. OTT 0
63. VCT 0
64. SHT 0
65. KILR 0
66. PLLFG 1
67. FSCFG 0
68. BPLLFS 0
69. HPLLFS 0
70. VSSL 3
71. HSSL 8
72. BGPW 7
73. BGPS 3
74. VTVH 0
75. FSCOFF 1
76. NRZOFF 1
77. NSDSW 0
78. ADPDS 1
79. ADCLKS 3
80. HIZEN 0
81. EXTDYCO 0
82. SYSPDS 0
83. ADCLPSTP 0
84. ADCLPFSW 0
85. HCNTFSYN 0
86. CNROFS 0
AD9883A
AD9883A_NVRAM
RED_GAIN 101
GREEN_GAIN 128
BLUE_GAIN 101
RED_OFFSET 51
GREEN_OFFSET 52
BLUE_OFFSET 61
HD2-CHIP
1.IN/OUT EXT/D1
2. WINOW ID M
3. XPOS 46
4. YPOS 8
5. W SIZE 720
6. H SIZE 480
hdphil is offline
post #9 of 405 Old 02-28-2004, 01:53 PM
Bremerton's Avatar
It seems to me these settings are pretty UNIVERSAL which is really good, most HDTV sets differ very much in the service menu. We might actually make some very good progress here comparing these good idea!!
Bremerton is offline
post #10 of 405 Old 03-01-2004, 09:01 AM
kevlo9's Avatar
Where is the BEST place to get the OFA remote?
kevlo9 is offline
post #11 of 405 Old 03-01-2004, 09:24 AM
Radio Shack, most likely. Circuit City. Best Buy. Any place like that.
post #12 of 405 Old 03-01-2004, 08:16 PM
hdphil's Avatar
i use the radio shack 150-2116 with a LCD screen
TV code 0178
exit setup mode ,then press "P" then your discrete code
right and left arrows change your settings
have fun,
write down your values
be sure to let everyone know what happened!
hdphil is offline
post #13 of 405 Old 03-02-2004, 12:15 AM
kevlo9's Avatar
AM I WATCHING MOVIES CORRECTLY?
I have my Toshiba SD-3800 dvd player set to 16:9....
should I watch movies in 4:3/16:9/set by program ratio?
THANKS.
kevlo9 is offline
post #14 of 405 Old 03-02-2004, 02:33 AM
Bremerton's Avatar
hdphil you totally skipped 89!!! mind posting it or editing your post?
:p
post #15 of 405 Old 03-02-2004, 05:40 AM
edogg's Avatar
kevlo,
16:9 but 'set by program' might work too i can't remember.
edogg is offline
post #16 of 405 Old 03-02-2004, 09:29 AM
kevlo9's Avatar
Is it better to have your dvd player set to 16:9 or 4:3? Or does it matter? I notice that when I have my player set to 4:3 widescreen and I watch a movie there are no double bars, but in 16:9 you can see the double bars.
kevlo9 is offline
post #17 of 405 Old 03-02-2004, 10:00 AM
Wendigo's Avatar
Do all the OFA remotes have the ability to enter discrete codes? I'm thinking about the URC-6131, because it's really all I need for my other components.
Wendigo is offline
post #18 of 405 Old 03-02-2004, 10:26 AM
edogg's Avatar
since the dvd your watching isnt 16:9 or 1.78:1 its propably 1.85:1 or 2.35:1 you will see double black bars. if you sink the brightness enough they should go away.... almost. ;-)
edogg is offline
post #19 of 405 Old 03-02-2004, 11:39 AM
kevlo9's Avatar
So is it better to have your player set to 16:9 or 4:3?
THANKS.
kevlo9 is offline
post #20 of 405 Old 03-02-2004, 01:53 PM
Jon7athan's Avatar
Configure DVD player to 4:3
In the menu of the DVD of your choice if you are give an option:
Choose 16:9 to watch title as originally shot, you will have black bars at top and bottom.
Choose 4:3 if you want to watch the movie filing up your set with no black bars
Jon7athan is offline
post #21 of 405 Old 03-02-2004, 03:45 PM
edogg's Avatar
ithink that by using 16:9 mode on the dvd player and your zenith and using anamorphic dvd's you will be using more lines than if you viewed the same dvd using 4:3 on both the set and the dvd player. i think...lol
with 4:3 you don't have to see the double black bars though.
pick your poison....lower resolution or double black bars
i use 16:9
i believe it looks much better(though i hate the double bars!)
try both ways for yourself
I actually tried to mask the set using some black foamboard.,i've got way too much time on my hands..great results but really a pain with all of the different aspect ratios.
if you turn down the brightness to like 30 the two blacks blend pretty well.
edogg is offline
post #22 of 405 Old 03-02-2004, 07:00 PM
Whoah, whoah, slow down there.
Let me make sure I understand you.
DVD and the Zenith. The black bars don't bother me. Keep them and get best resolution?
I have the Zenith set to "let program determine aspect ratio." The DVD player will set at 16:9 all the way.
post #23 of 405 Old 03-02-2004, 07:10 PM
edogg's Avatar
i'm sorry what is your question? i am confused.
edogg is offline
post #24 of 405 Old 03-02-2004, 08:47 PM
hdphil's Avatar
maybe this will help, 16:9 is like oil and 4:3 is like water they just don't mix .
hdphil is offline
post #25 of 405 Old 03-02-2004, 10:10 PM
kevlo9's Avatar
Thanks for all the replies!
I thought I had mine setup correctly.
One more question...
When selecting the ratio on the remote, selecting set by program while watching dvds seems to be the same as 4:3 mode. Is that correct?
Anyways, I plan on buying the OFA remote this weekend and plan on doing some tweaks via the service menu. I'm sure that I will have MANY more questions. :D
Thanks again, youguys have been a BIG HELP!
kevlo9 is offline
post #26 of 405 Old 03-03-2004, 07:08 AM
Cool. Just don't get too carried away. I find personally, that the TV is good enough that I feel no need to touch the service menu, and I think the remote it comes with is pretty darned good as is.
Select "Set by program" just means automatic. True HD probably will send you to the letterbox format, otherwise you should see 4:3.
Someone feel free to doublecheck me on that. ;)
post #27 of 405 Old 03-04-2004, 11:24 AM
kevlo9's Avatar
What is VM? From what I've heard, it should be turned off. Is this correct?
kevlo9 is offline
post #28 of 405 Old 03-04-2004, 04:05 PM
palebluedot's Avatar
I just got this set a few days ago and I have a problem with the VMoire settings. The vertical lines are perfectly straight, but the horizontals bow inward (more-so in the center). Anyone found a menu item that will help with this type of correction? TIA
palebluedot is offline
post #29 of 405 Old 03-05-2004, 10:27 PM
kevlo9's Avatar
I was wondering...
Since I watch MOST stuff(dvds & HDTV) in 16:9 mode should I go thru and setup the set again in 16:9 mode with a setup disc? Has anyone else done this? Is there a difference in the settings for 4:3/16:9?
THANKS.
kevlo9 is offline
post #30 of 405 Old 03-07-2004, 08:37 AM
jakob1321's Avatar
"Set by program" won't work with 480p, because it only detects 16:9 at 720p & 1080i. thankfully, using the discreet codes, you can program all of this into a macro if you have a ofa remote. I feel like this is a huge oversight on zenith's part.
If you're not dealing with a loved one who's unwilling to hit a ration button on the remote, you should *always* use 16:9 on your dvd player.
If you use 16:9, your zenith gets the full resolution (854x480) and vertically compresses the screen draw. If you tell your dvd player to letterbox, it will only send a 4:3 signal with the widescreen image downrezed, so you're looking at 640x360 being sent to it, or only 56% of the information available on the dvd. By going with 16:9, your dvd player no longer has to dumb down the signal, and you should notice a huge difference in picture quality.
Hope that helps.
jakob1321 is offline
Closed Thread Direct View (single tube) CRT Displays
