The Official Kd-34xbr960 Thread - Page 273 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
Old 06-30-2014, 01:04 PM
ArmorOfGod7's Avatar
Originally Posted by Floydage View Post
Keep in mind the auto-degauss circuit needs time to cool off. Some TVs without thermal or timer protection will fry the circuit if you get crazy turning it on/off quickly; the ones that do have it you'll notice you won't hear the whomp sound right after the first try.
Now if yours is working (whomp sound?) and you haven't moved it then it should be sufficiently degaussed from normal usage. I have heard that it's better to plug it directly into an outlet for degaussing; I've personally never had an issue with using a surge protector though.
My Panny has a corner problem but it looks like it may have been dropped on that corner. I've never popped it open to see if a magnet broke off or maybe the degauss coil somehow slipped over the corner. For the time-being I've just stuck some old pieces of ferrite (or weak magnets) on the outside around the corner to improve the color; these pieces came from a scrapped CRT, the ones on the back of the tube for alignment.
Thanks for the additional info. I'll try plugging it directly into the wall and do a few power on's with time in between. If that doesn't help, I'll just give the thing away.
gary777 likes this.
ArmorOfGod7 is offline
Old 06-30-2014, 04:08 PM
Originally Posted by homerging View Post
I remember somebody claiming that leaving it unplugged for a while before plugging it directly into the wall socket and turning it back on would be more effective but I can't remember their reasoning.
If not that, it's possible convergence is off which can be altered in the service menu.
I don't see convergence anywhere in the menu, where exactly would that be?
Old 06-30-2014, 07:44 PM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 180
It's in the service menu, not the user menu.
DSperber is offline
Old 07-01-2014, 09:11 AM
homerging's Avatar
Quoted: 31 Post(s)
THE SONY SERVICE CODES - Articles, Comments, Discoveries
The service menu isn't friendly to novices and can brick your television if misused. Don't "reset" to pre-factory settings. It may be useful to see a picture of what is going wrong
gary777 likes this.
homerging is offline
Old 07-01-2014, 10:19 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Doesn't sound like a convergence problem:
http://www.repairfaq.org/samnew/tvfaq/tvcrtpca.htm
gary777 likes this.
Floydage is offline
Old 07-06-2014, 11:33 AM
Posted it over in the Classifieds section if anybody is interested:
Sony WEGA FD Trinitron 34" KD-34XBR960
Old 07-06-2014, 06:25 PM
BTV Mark's Avatar
Bulk tape eraser
Originally Posted by LiquidSnake View Post
If the only problem is discoloration, then yes that's fixable. The screen needs to be degaussed. Multiple off-on states should do this, but if it remains, a manual degaussing with a degauss wand will fix the problem.
(Sorry...I haven't checked this site for a couple weeks.)
Yes, this works! I have used a hand-held "bulk tape eraser" many times on various CRT's over the years. It takes a little "courage," but gets rid of the most stubborn colored blotches.
Here's the procedure: Turn the TV on. Place the bulk tape eraser an inch or two from the screen. Switch it on. (Expect to see a "rainbow" pattern. DON'T WORRY...things will be OK.) Move the bulk eraser slowly around the affected area of the screen, in a slow circular motion. Then, slowly...slowly...pull it away from the screen until it's at least 10 feet away. Then switch it off.
The problem should be gone. If not, repeat the above steps. You'll get it.
Now, the hard part may be finding the hand-held bulk eraser. They used to be very common, but of course they're rare now. I have a Videoraser Model VX-1401. Here's a link to an e-Bay auction:
http://www.ebay.com/itm/Sonar-Radio-...item58b166f4e0
Here's an e-Bay listing for a Radio Shack model, again an e-bay auction:
http://www.ebay.com/itm/like/311000576394?lpid=82
Good luck!
Mark
homerging likes this.
BTV Mark is offline
Old 07-09-2014, 08:14 AM
Joseph Dubin's Avatar
Quoted: 62 Post(s)
Liked: 44
Smile
Good luck!
Mark
Hi Mark,
Still, unplugging the set for about five minutes and then plugging it back directly to the wall socket is probably the easiest way of eliminating both the color distortion and also returning the picture to it's most vibrant quality (somehow they go hand in hand). Even without the magnetic build up, I do this once a month and do notice the "pop" returning to it's stunning picture.
Joseph Dubin is offline
Old 07-09-2014, 08:35 AM
BTV Mark's Avatar
Originally Posted by Joseph Dubin View Post
Hi Mark,
Absolutely agreed, Joseph. My procedure is definitely something to do only when normal trouble-shooting methods don't work. I should have mentioned this. In my case, this procedure is necessary once or twice a year.
Mark
BTV Mark is offline
Old 07-13-2014, 06:01 PM
baklakiller's Avatar
I just got an xbr960 & the picture seems a bit out of focus/blurry. Is there some kind of focus pot i can adjust or change in the service menu?
baklakiller is offline
Old 07-17-2014, 07:41 PM
gary777's Avatar
Quoted: 50 Post(s)
Can you post a photo of the screen with the blurry picture. I would also ask the sell if he ever had the back off and touched anything.
You might want to post this question here also:
You have a Sony that won't power on and the standby light blinks... Help and suggesti
gary777 is offline
Old 08-20-2014, 08:59 AM
BTV Mark's Avatar
Free to a good home
Well, the time has come, and we're looking at a XBR-55X850B 4k set to replace our wonderful '960. (Any comments on whether that's a good choice for an upgrade?)
I thought I'd offer it here first, rather than letting the dealer haul it away. So "free to a good home"--if you can pick it up. My bad back won't be able to help. The TV and Sony stand are in the basement rec. room in North Suburban Chicago. The TV had the two "flashing light" driver chips replaced about 3 years ago, so it's in perfect shape.
Mark
BTV Mark is offline
Old 08-21-2014, 08:27 AM
homerging's Avatar
Quoted: 31 Post(s)
There is a review here
http://www.avforums.com/review/sony-...v-review.10556
You could try putting the XBR960 on Craigslist or eBay as a dealer would just send it to be junked.
Old 08-21-2014, 11:20 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Mark
Very noble of you! I was going to tell you there's a classified section on AVS but I see you posted there too. In the event there's no AVS takers indeed try CL. You can even make a few bucks there especially with the stand, heck the stand is more valuable to most folks to place their big screens on and much easier than the TV to move.
Wish you were here,
Pink Floydage
P.S. Been up that way a few times when I worked for Motorola. Mostly Arlington Heights and surrounding suburbs but a few trips downtown for fun. Love the food, especially the pizza!
Floydage is offline
Old 08-22-2014, 02:04 PM
homerging's Avatar
Quoted: 31 Post(s)
I'm curious, how high off the ground does the stand measure?
Old 08-22-2014, 08:55 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
And is it the "Sony stand" that is made for and nicely matches up with a 960? (That was my assumption).
Floydage is offline
Old 08-25-2014, 08:04 AM
BTV Mark's Avatar
Sony Stand
Yes, it's the matching Sony stand.
It "stands" 18" high, which puts the bottom of the TV frame at 19."
Mark
Floydage likes this.
BTV Mark is offline
Old 08-25-2014, 08:05 AM
BTV Mark's Avatar
Thanks! This is a very nice review.
Mark
BTV Mark is offline
Old 09-27-2014, 12:20 PM
AEntreri0's Avatar
Liked: 0
I bought my 960 in 2008 on craigslist and it has served me well since then until two months ago when the screen gained a pink hue when a significant portion of the image was white. Soon, images on the screen in areas of high contrast began producing faint horizontal bands, and finally the screen would flicker and darken when turning on the display. All of this was with the component input, so I tried HDMI from my PC and I was truly dismayed: with nothing but my white mouse cursor on a black background, the screen was red all the way down to the level of the cursor, where it was also red to the left of the cursor horizontally.
I've since moved to an apartment for medical school and I've left the 960 at my parents' house, but I'm hoping it can still be fixed. Until these problems began, the tube had fantastic convergence and no problems with brightness or distortion. Does anyone have an idea what's wrong and if it's reparable?
AEntreri0 is offline
Old 11-06-2014, 07:20 AM
JA Fant's Avatar
Quoted: 197 Post(s)
Liked: 229
Welcome! AEntrei0
read back over this thread and there is some mention of the 'red screen of death'.
I have had my 960, 10 years, next month- I hope I can get as much time out of this CRT as possible
JA Fant is offline
Old 11-06-2014, 07:22 AM
JA Fant's Avatar
Quoted: 197 Post(s)
Liked: 229
Second note-
every so often, I get a light green screen, while watching tv programming (not DVD viewing).
I simply turn off the crt, wait 1-2 minutes, then turn back on- picture returns to normal viewing...
JA Fant is offline
Old 11-11-2014, 05:07 PM
drvais's Avatar
Quoted: 92 Post(s)
Liked: 55
Originally Posted by JA Fant View Post
Second note-
In that case, it's easier to just change or unplug the HDMI input rather than turning off the set.
unOFFICIAL D-Box FAQ here!
unOFFICIAL D-Box HEMC FAQ here!
Hail to the King, baby!
drvais is offline
Old 11-11-2014, 08:06 PM
JA Fant's Avatar
Quoted: 197 Post(s)
Liked: 229
Many Thanks! drvais-
do you get this (issue) w/ your 960 as well?
JA Fant is offline
Old 11-20-2014, 06:12 AM
First XBR's Avatar
I am moving to Houston in February & can't fit the tv in my trunk. I really hope I can find another one there. I watched Guardians of the Galaxy on Saturday & it was hard to believe, how good the picture looks, wow.
First XBR is offline
Old 11-28-2014, 06:33 PM
Bracamonte's Avatar
Recently, I'm noticing grainy text on my KD-34XBR960 when in HD, mostly when playing games on my xbox 360. The only solution I know of was to decrease the brightness and picture, but I usually don't like dark images. Does anyone know any other solutions?
ID:	390490   Click image for larger version
Bracamonte is offline
Old 12-09-2014, 07:01 PM
DSperber's Avatar
Quoted: 224 Post(s)
Liked: 180
I have my own XBR960 that's in absolutely perfect condition which I'd like to sell. I upgraded to a 65" Panny 65VT50 about two years ago and really haven't had the 960 powered on but maybe five times in these past two years. I've been the sole owner since I bought it new in 2004, and it was what I thought was tweaked to perfection (in service menu and user menu) until I decided to finally have it calibrated after seeing what difference a calibration could make when I had D-Nice do a calibration on my VT50.
So one of those power-on times for my 960 in the past two years times was for D-Nice to return a second time to do a calibration of my 960. Results were amazing. The two sets are physically side by side in the same room so seeing them both on together and tuned to the same program is quite startling, as the color is absolutely the same on both although the VT50 is of course 4X the size of the 960 so that it's hard to mentally do an honest comparison, and also the VT50 is brighter than the 960. But otherwise, they look like Mutt and Jeff because the color on both is identical, and superb.
Anyway, I'd like to find a good new home for my 960. I really have other intentions for the entertainment credenza it's been sitting on for 11 years.
I'm in Los Angeles. PM me if you're interested in acquiring it.
DSperber is offline
Old 12-19-2014, 04:54 PM
JA Fant's Avatar
Quoted: 197 Post(s)
Liked: 229
Sorry to read about your wanting to part w/ your 960. 10 years of ownership here, hopefully another 10!
For those considering this CRT- Go For It!
JA Fant is offline
JA Fant's Avatar
Quoted: 197 Post(s)
Liked: 229
I wished I lived near you, DSperber
JA Fant is offline
Old 01-01-2015, 08:22 AM
JA Fant's Avatar
Quoted: 197 Post(s)
Liked: 229
Happy New Year!
JA Fant is offline
Old 01-04-2015, 02:33 AM
9604me's Avatar
WOW, wanted a 960 since 2004, ended up settling for a 970 in 2006 and have used the hell out of it ever since. Started really looking for a used 960 about five years ago. FINALLY took a ~10 hour road trip to pick one up last week for 100bucks(960 manufactured 2004). Unfortunately it wasn't an "N" model, but I snagged it up. Was dismayed when I got it home that I had to turn the brightness up so much for a decent picture. When I went to look at it I thought nothing of the the "picture" and "brightness" settings being in the high forties to fifties for a good pic(I didn't realize the adjustablel scale did NOT go to 100). Is it normal for tv and hd to have these two settings in the high forties to fifties?
Also, It had a "dent" in the center of the screen and a constellation of tiny dots around the dent in the anti-glare film. SO, after much reading around here on the subject, and mentions of the underlying outer screen being acrylic or plastic, and other horror stories of chemicals, and buffing, and scrubbing, and ruining, etc. I proceeded to tear apart the cabinet and front bezel(partially) and remove the film with great trepidation...It took a while, and shredded my hands, but I managed to peel off the layer after getting ahold of a top corner of the film, where the tube it rounded in the corner. It IS glass underneath, and it does look amazing compared to my 970 All you have to do to see what's making the difference is shine a flashlight at the screen(while not powered on) and see the difference in size of of the apertures between the two...
9604me is offline
