The Official Kd-34xbr960 Thread - Page 275 - AVS | Home Theater Discussions And Reviews
 10Likes
post #8221 of 8247 Old 01-15-2015, 08:18 PM
AVS Club Gold
DSperber's Avatar
Quoted: 126 Post(s)
Liked: 131
Originally Posted by 9604me View Post
Also, I'm VERY interested in any way to capture video/audio out via firewire...I came across alot of stuff searching around, my questions are: Besides some specific tape recording mechanisms, is there any device readily available that will communicate with the 960 via firewire and record output?
Recording of HD programs in original bit-perfect 720p/1080i HD quality including original digital audio present in HDTV content? Is that your desire?
There are no disc-based HD recording solutions (to transcribe programs to recordable media, as we use to do with tape-based VCRs) available in America, as "the Suits" don't want anything simple or user-friendly to allow home recording to the user-friendly BluRay media. There are PC-based solutions, including the ability to edit copy-freely content and then burn-to-BluRay blank media, but only for copy-freely content. You cannot do anything with copy-protected content (e.g. programs provided in encrypted form by your cable service provider) except for play it back through cable company hardware or through cablecard-enabled decrypting.
Although they are no longer manufactured, you can use DVHS VCR's (made by JVC, e.g. DT100U which also includes a built-in OTA/ATSC tuner if you have a roof antenna and can receive free local broadcast networks that way) which are still available on the used market. These can record HD digital content in bit-perfect digital form to DVHS tape (although they can also be forced to use SVHS tape in digital mode), either directly via their OTA/ATSC digital TV tuner, or fed with copy-freely content via firewire.
I myself have five of these DVHS VCRs (they used to get quite a bit of use in the old days), but today not one of which is still currently actively being used because they've become obsoleted ever since cable companies decided to encrypt 100% of their channels. But if you have roof antenna capability, you can still use these DVHS VCR's to make recordings of OTA/ATSC channels and then play them back to the 960 in true bit-perfect HDTV form... either via component video, or more preferably via HDMI.
As far as recording TO the DVHS VCRs FROM the 960 via firewire, that is also possible (using the 960's iLink 1394 connectors and connecting to the firewire connectors on the DVHS VCR) when the source is the 960's built-in OTA/ATSC tuner... as long as the original program content is copy-freely and not encrypted. The outboard DVHS VCR's are not cablecard enabled, and so possess no way to do the required decryption if necessary. Also, the DVHS VCR's are built to honor copy-once protection flags, designed to allow 1st-generation offloading of content from a DVR to a DVHS VCR via firewire (from DVR's that supported this, like from Motorola/Cisco). But the VCR won't allow you to connect a second DVHS VCR via firewire and make a digitally-perfect 2nd-generation copy to the second VCR, since that violates the "copy-once" notion.
I honestly don't know about whether cable-provided encrypted content that is fed to a cablecard-enabled 960 can then feed that content to an outboard DVHS VCR via firewire (same as a cable company DVR would) successfully. If it provided the original encrypted content then that obviously would not be usable, since there's no cablecard in the VCR. If it provided the decrypted content (thanks to the cablecard in the 960) then where is the copy-protection which still should be present? So I'm not sure if cable-provided content can be fed to the firewire outputs of the 960, but it doesn't seem plausible to me.
If so, would only tv channels be output via the firewire, or would also hdmi inputs(ps3, etc) output a recordable output via firewire?
Well for sure any TV channels from the built-in OTA/ATSC tuner in the 960 would be output via firewire.
However I'm almost positive that cablecard-facilitated content would not be delivered to the 960's firewire output, for the reasons I described above.
As far as external input (e.g. HDMI input) to the 960 that is absolutely not going to be sent to firewire. Remember that firewire connections are intended to carry the original MPEG-2 compressed content in its "relatively low bitrate", not the "high-bitrate" uncompressed video output delivered to the 960 via HDMI (where the decoding/decompression has been done by the source device and is delivered over HDMI to a secure HDCP-enabled device). Again, this is all an attempt to prevent 100% bit-perfect digital piracy.
DSperber is offline
post #8222 of 8247 Old 01-16-2015, 09:09 PM
9604me's Avatar
Thanks again for the very informative reply! Thanks for confirming I couldn't possibly capture inputs to the tv thru the firewire link. Guess I'm not that interested in capturing tv....Definitely not to tape. I didn't think any capture cards for pc would work because of no existing drivers for the 960? Is that correct?
Thanks again.
9604me is offline
post #8223 of 8247 Old 01-17-2015, 11:17 AM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
Interesting stuff for me to know too.
9604me, I have sort of the Panansonic version of one of these TVs and use an HDD/DVD recorder and a DVD recorder to record HD OTA channel content via converter boxes with s-video outputs. At this screen size and being a CRT there's not much degradation, I have to be sitting real close to notice. And I personally like the pic better with the output set to 480i vs. any 'fuzzy' upscaling from the recorders (my Panny doesn't have DVI or HDMI so I use component, but the recorders do have digital outputs). Generally DVD quality as I use the highest quality recording settings (i.e. 1 hour per DVD).
Anyhow my thinking is that you might see if your 960 has any 'monitor' A/V outputs that could work for this. My Panny has s-video and composite outputs (+ audio) but it doesn't have a cable input to try this scenario.
Floydage is online now
post #8224 of 8247 Old 01-23-2015, 02:10 PM
meowmix's Avatar
Kd-34xbr960 10 red blinks and rolling screen
Hey guys. I have a new issue with my Kd-34xbr960 and after being unsuccessful scouring the internet for a solution I thought id post here. I love this thread and ive read through most of it over the last 2 years of owning this TV.
for the last 2 months when i turn on the TV, on any input, from any video source, component 5, component 6, S video etc...the red light blinks 11 times and the screen jitters, rolls, and has problems adjusting itself in the center.
This goes on for about 2 minutes after startup and then its fine. Here is a video i took of it starting up the super nintendo.
https://www.youtube.com/watch?v=j_8q...ature=youtu.be
I have taken the back off and tried adjusting the screen knob multiple times without success. Perhaps im adjusting it incorrectly?
Anyone have any ideas???
thanks guys
meowmix is offline
post #8225 of 8247 Old 02-05-2015, 09:59 AM
jhunterthompson's Avatar
slight shadow in 2 corners
Hello,
I recently purchased a 34XBR960. I notice that when the screen is on a light color, either white or 25% gray scale, there is a slight bluish green splotch on the left side about 1 inch or so above the corner and on the top right, in the corner.
I can adjust it via the landing menu and get it reduced but it never completely goes away. My adjustments are at the limits of the menu, for instance reducing the LB to 40 and increasing the RT to 220 or so.
I was wondering if having the values at such extremes will have a negative consequence on the life of the television or is there are other service menu settings which may help alleviate the issue.
Thank you
jhunterthompson is offline
post #8226 of 8247 Old 02-05-2015, 03:04 PM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
Since you recently purchased it, and I'm assuming recently moved it, has it had very many on/off cycles in its new compass position to fully degauss? And if yes, do you hear the 'boing' sound on power-up to feel confident that the degauss circuit is working properly?
My Panny ~version of one of these has a similar problem with one corner a little pink and another a little blue. It has a crack in the cabinet on the pink side so I'm thinking it was dropped, maybe altering the CRT magnets. Unfortunately I couldn't find enough service menu info on this obscure model so the best I could do was place some weak magnets on the cabinet around the pink corner; these were old ferrite strips from the back of a long gone CRT, very weak in magnetism (it doesn't take much). Fortunately the pink corner is lower left and my vision isn't drawn that direction very much. The blue corner is so mild I hardly notice it, at the moment I don't even remember which corner it is.
post #8227 of 8247 Old 02-05-2015, 04:07 PM
JA Fant's Avatar
Quoted: 94 Post(s)
Liked: 102
Welcome! to the club- jhunter
JA Fant is offline
post #8228 of 8247 Old 02-06-2015, 05:13 AM
Thank you for the reply.
Yes, I recently moved it and it admittedly banged around a bit in the back of the car. Not too much but a little. I do not believe there was any physical damage in moving it.
There have not been many power on cycles as i have had it 6 days. Maybe two cycles a day.
As i mentioned i am able to reduce it greatly via the landing menu and have gotten it to a point where it is only visible when the corners are white or very light. As soon as they get a color the splotches seem to blend in enough so i don't notice. Also, to be fair, i never mentioned it to anyone in the house and nobody but me has noticed it. I'm just picky like that i guess.
Anyway, I tried a few smaller refrigerator magnets last night and they had no effect when held to the case. My magnet collection is either very weak or far to strong and the color distortion was very visible when i got close to the screen.
I held the stereo speakers to the case to ensure the shielding was there and working properly and they caused no distortion either so i am confident that it is not any of the equipment near the TV causing it.
If it is as good as it will get as it is, i can live with it. The TV was only $120 so i don't feel like I got a bad deal.
Thank you.
post #8229 of 8247 Old 02-06-2015, 09:35 AM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
Sounds like enough cycles. Unless maybe they had some speakers, etc. near it for a long time and may take longer to snap out of it. Yeah white is when mine is most noticeable too, which makes sense since the colors must combine equally to generate white. Sometimes I notice it when there's an 'opposite' color. I hope my Panny has the landing function if I can ever figure out the service menu, thanks for that back at ya.
post #8230 of 8247 Old 02-15-2015, 11:14 AM
JA Fant's Avatar
Quoted: 94 Post(s)
Liked: 102
jhunter-
did you know the TV's history prior to buying it?
JA Fant is offline
post #8231 of 8247 Old 02-17-2015, 06:34 AM
Originally Posted by JA Fant View Post
jhunter-
Hello,
Not much. I am the second owner and i wanted to upgrade my older 27 inch 4:3 tv and wanted a CRT with HDMI so i could plug my htpc into it. This one fit the bill and the price was right. It was a 1 1/2 hour drive to the guys house and i didn't bother to look much more then to see it worked.
I took some pictures of the light blue discolorations.
They are in the upper right and lower left when the screen is list. I am unable to adjust it away with the lading menu.
They only show on a bright screen,
http://imgur.com/2H8msYZ,oS2FLfv,uDUutq7#0
post #8232 of 8247 Old 03-31-2015, 10:24 AM
Joseph Dubin's Avatar
Hi all,
I'm afraid I will be saying goodbye to this particular forum.
Late last week got the dreaded rapid on and off blinking and the set would not turn on. Unplugged it for a while, no dice. Kept on turning it on and off and maybe after ten minutes or so it would finally go on. But the next day the same problem and after ten or so minutes of attempt, would go on. Then the next day struggled again a bit longer (keeping it unplugged over night) and would not go on at all. One time I thought it would as I heard the diffuser go on but after the fourth red light would hear that loud click which would indicate something was wrong.
Know others had a circuit board replaced but this was not worth fixing because it would have needed a technician which is quite costly and the set already had areas where the coating was off. So ordered the Sony KDL 50W800B and will use the 360's stand. Wish me luck.
Had to discard it myself. At 63 was not going to risk my health so slid it off the stand and let it fall to floor (told better half not to get scared of noise, she still did LOL) then got a dolly and after tilting it against a love seat was able to wedge the dolly onto it and then it was just a matter of rolling it downstairs to our dumpster and letting our custodial people deal with it then (our people are not allowed to do this even on their own time).
So it's been nice chatting with all of you and sorry I have to go. It's a shame, still had a great picture despite ten years old but from what I read, this new Sony will be a nice replacement and it is much bigger.
Joe
Joseph Dubin is offline
post #8233 of 8247 Old 04-01-2015, 09:02 AM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
RIP 960, hope you make it to e-cycling.
Adios Joe and GL with your new Sony! At least you have the stand to remember the old one by.
post #8234 of 8247 Old 04-23-2015, 02:44 PM
JA Fant's Avatar
Quoted: 94 Post(s)
Liked: 102
Take Care- Joseph
JA Fant is offline
post #8235 of 8247 Old 04-24-2015, 10:57 PM
Hi Floyd and JA,
Wanted to wait till had the 50w800b for a while to compare some thoughts.
Will not talk about screen size for the impact is obviously unfair. But LEDs have come along way in ten years. There is still a certain "punch" from not being flat I miss from the 960 but the sharpness, color, black and yes, even the depth have to admit has me floored so the tradeoff is worth it.
Will say the 960 still holds its own when recognizing one is comparing a modern set to one that is ten years old. That is as good a tribute one can give. No regrets having it all these years for the pleasures it gave us.
post #8236 of 8247 Old 04-25-2015, 08:42 AM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
There were some 960 aficionados here that went for the Panasonic plasmas albeit the higher-end models (I think VT models). Sounded like the closest one could get to a CRT/960 and of course with some parameters being better. Probably getting hard to find new now though.
post #8237 of 8247 Old 04-25-2015, 11:54 AM
Hi,
Originally wanted plasma too but on the most part those are not being manufactured anymore. Did s lot of research cause one cannot go by store demos.
Floydage likes this.
post #8238 of 8247 Old 04-28-2015, 04:51 PM
9604me's Avatar
I recently found a KD-34XS955 with stand for sale a few miles away...Am I to understand this is basically the same as my 960 sans PIP, and the now defunct features like i-link and firewire? Is it really the exact same tube?
9604me is offline
post #8239 of 8247 Old 04-28-2015, 06:34 PM
JA Fant's Avatar
Quoted: 94 Post(s)
Liked: 102
I, too, have often wondered about the picture tube in both the 34XBR800 and 34XS955?
At any rate, all of these sets are very fine CRT(s).
JA Fant is offline
post #8240 of 8247 Old 04-28-2015, 08:30 PM
I think the picture tube is not super fine pitch.
post #8241 of 8247 Old 04-28-2015, 08:35 PM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
SFP tube yes 955, 800 no per this:
http://en.wikipedia.org/wiki/FD_Trinitron/WEGA
I think if you search some old reviews like CNET for the 960 you'll see mention of changes from the 955.
post #8242 of 8247 Old 04-30-2015, 10:28 AM
sokoban's Avatar
Liked: 0
Anyone Want a 960?
I have a 34XBR960 I'm looking to get rid of. Located in Lexington, KY. Anyone interested?
sokoban is offline
post #8243 of 8247 Old 04-30-2015, 08:22 PM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
There's also a classified section on AVS:
http://www.avsforum.com/forum/256-direct-view-crt/
but nice of you to offer it here first.
post #8244 of 8247 Old 05-01-2015, 10:56 PM
RWetmore's Avatar
Quoted: 176 Post(s)
Liked: 110
Yes, it's the same exact same Super Fine Pitch Tube, but the XS955 does not have an anti-glare coating (which I think is a plus).
RWetmore is online now
post #8245 of 8247 Old Yesterday, 10:33 AM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
Actually it does, it has to have an N suffix to not have the coating:
I think the only differences between the 955 and 960 were certain features, the major stuff was the same.
post #8246 of 8247 Old Yesterday, 08:18 PM
RWetmore's Avatar
Quoted: 176 Post(s)
Liked: 110
I owned the XS955 and it did not have an anti-glare coating, where as the XBR960 did (which I removed).
post #8247 of 8247 Old Today, 08:35 AM
Floydage's Avatar
Quoted: 56 Post(s)
Liked: 51
That's weird RW if yours doesn't have an N suffix per Sony model number configurations. Unless someone removed the film before you got it. Or that Wiki page is wrong for the 955s, I've never researched it more than that. I'm pretty sure the 960s are correct from what I've seen elsewhere. But glad you didn't have to mess with the stuff.
Reply Direct View (single tube) CRT Displays
