The Official Kd-34xbr960 Thread - Page 281 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #8401 of 8429 Old 11-27-2016, 05:29 AM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Welcome! Forest Shepard
JA Fant is online now
post #8402 of 8429 Old 11-27-2016, 05:30 AM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Welcome! JKonrad 1993
post #8403 of 8429 Old 12-11-2016, 01:40 PM
Liked: 1
Hello Forum. I have a 34XBR960 that I bought new in 2004. It has died last week. I turn it on see three red blinks and the tv shuts off. Is this an easy fix? I had the set calibrated in 2005 and I have never seen a better picture.
JA Fant likes this.
boonrag is offline
post #8404 of 8429 Old 12-12-2016, 11:52 AM
Dean_KS's Avatar
Typical problem is a certain IC fails. There are two and one has failed. You would replaced both.
IF 6 OR 7 BLINKS.
http://nickviera.com/av/sony_wega/
3 blinks is a power supply problem. Either the power supply or IC 6505 that reports the problem.
6-7 blinks continued
Are you able to do work on IC boards with fine traces? There are two 16 pin IC's to remove.
You need a fine tip temperature controlled soldering iron, solder wick and solder sucker.
The back cover is removed and the IC is then exposed.
It is not an easy job. You need decent skills/experience. But if you fail, not much lost.
There is a repair kit with the two IC's and two sockets. The cost of the kit is trivial.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
boonrag likes this.
Dean_KS is offline
post #8405 of 8429 Old 12-12-2016, 07:10 PM
vash32's Avatar
Liked: 2
Just got a used KD-34XBR960 for just $50 and love it a lot.. however for just $50 is does have some problems that I'll like to get fixed. I've more or less removed all the overscan but I have some convergence problems & I think the disk magnets need to be adjust as the corner are not right. (or can the magnets go bad over time?)
JA Fant likes this.
vash32 is offline
post #8406 of 8429 Old 12-13-2016, 07:44 AM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
vash32
Welcome! hope you receibe the help requested to fix your 960. I have had mines for 11 years, built in 2004, w/o issues.
There is a wealth of info in this thread. Keep reading from the beginning and good luck!
post #8407 of 8429 Old 12-13-2016, 11:40 AM
Dean_KS's Avatar
These TVs are sensitive to external magnet fields. If there is or has been non shielded speakers near by you can have problems.
JA Fant likes this.
Dean_KS is offline
post #8408 of 8429 Old 12-13-2016, 02:13 PM
vash32's Avatar
Liked: 2
Originally Posted by JA Fant View Post
vash32
I've seen some info on hare so far & its be very helpful. I be sure to keep reading. The problems are not very bad but all the HD CRTs that I tired out so far all got the same problems. I used two Hi-Scan models before this god or a home CRT.
I'm not sure if anyone has does this to it before or not, I know I have not. It does has this in the manual:
Disk magnets or rotatable disk magnets correct these areas a-d. Its only the four corners that same to have this problem. Its not seeable for more things but I can see it in games as I'm using the menu. I can also see some red, greed & blue lines some parts of the screen, that most likely the convergence.
JA Fant likes this.
vash32 is offline
post #8409 of 8429 Old 12-13-2016, 02:51 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Keep me posted -Vash32
post #8410 of 8429 Old 12-14-2016, 08:03 AM
Dean_KS's Avatar
The demagnetization coil really only works properly when there is no external field, ie from an shielded speaker.
If there is an external magnetic field, the demagnetization will imprint the magnetic field, not erase it.
Above may not have any application to your situation.
JA Fant likes this.
Dean_KS is offline
post #8411 of 8429 Old 12-14-2016, 08:30 PM
vash32's Avatar
Liked: 2
I'm not sure but from what I've seen online, I may need to position my yoke or move it back as it sames that can move off a little over time.
I'm thinking I'll need up just opening it someday soon & just do most of the things in the service manual.
Like what this guy has done to a older 36" that I may do the same from my old 28" that the same model type.
youtube com /watch?v=3SsLwcSKIOY
vash32 is offline
post #8412 of 8429 Old 12-17-2016, 07:11 PM
The Lizard King's Avatar
What's a fair price to pay for one with and without the modular SONY stand?
The Lizard King is offline
post #8413 of 8429 Old 12-18-2016, 02:20 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
I would say $100-200 depending on condition. Make sure that the set has never been in a non-climate controlled space.
post #8414 of 8429 Old 12-18-2016, 02:27 PM
If it's stored in a garage, that's a problem?
post #8415 of 8429 Old 12-20-2016, 12:34 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Yes- a tv such as this should never store in a garage, basement nor attic. Climate -controlled conditions only.
post #8416 of 8429 Old 12-24-2016, 10:52 AM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Merry Christmas- All
tanis38 likes this.
post #8417 of 8429 Old 12-30-2016, 02:18 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Getting ready to start another New Year w/ my 960N
post #8418 of 8429 Old 01-01-2017, 02:15 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Happy New Year!
post #8419 of 8429 Old 01-06-2017, 02:58 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Here's to another year w/ my 960N
JohnGZ28 likes this.
post #8420 of 8429 Old 02-08-2017, 02:17 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Hope you guys are still enjoying your 960/960N CRT sets.
post #8421 of 8429 Old 02-11-2017, 06:48 AM
I've never owned one, but I own two KD-36XS955 sets, and they are both still working just fine.
JA Fant likes this.
post #8422 of 8429 Old 03-02-2017, 01:50 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
very nice! Lizard King
post #8423 of 8429 Old 03-10-2017, 05:37 PM
captainsolo's Avatar
I love my set and got used to the slight problems with the curving of the upper left corner and a touch of side overscan once I did service menu tweaking.
What really drives me nuts are the phosphor trails. Otherwise it's a total beauty.
My current settings are:
Picture 20
Brightness 40
Color 31
Sharpness 27
Pro mode
I think my brightness may be a tad too high for movies and games seem to need a bit more.
My question is about inherent sharpness. I've seen some things appear that seems bit like edge enhancement halos and wasn't sure if there's some type of service menu controlled EE within the set itself. I have the menu VM totally off.
JA Fant likes this.
captainsolo is offline
post #8424 of 8429 Old 04-21-2017, 01:03 PM
Liked: 2
I've had a 960 for about four years. Been lurking here for all that time, and managed to fix a 40XBR800 thanks to the info here. Dragged the 960 with me from Arizona to California and don't think I'll ever get rid of it.
Anyone know if CRT calibrators are still around? I've spent many hours tweaking and taking notes on the service menu options, but I just can't get the geometry on point or the overscan when I try to reach something close to what a 1:1 pixel map would be. It hasn't bothered me until recently when I hooked up a PS4 Pro to it. Blu-Rays, DVDs, Laserdiscs, etc. still look fantastic, but either my TV is at its limit and new games are far too detailed to expect much clarity in the small text or the settings are way off. I'm thinking of either going the calibration route if that's still a thing or just grabbing a 9G Kuro and delegating the CRT to LD and old game duty. The anti-glare coating is pretty far gone too, but it's not noticeable at night at least.
JA Fant likes this.
lowibu is offline
post #8425 of 8429 Old 04-28-2017, 02:21 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Welcome! boonrag
hope you can find a repair tech.
post #8426 of 8429 Old 04-28-2017, 02:24 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Yes, there are many ISF CRT calibrators in California. Look at the ISF Calibrator section of these forums and post your request
post #8427 of 8429 Old 04-28-2017, 02:25 PM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
Display Calibration - top link for ISF providers.
post #8428 of 8429 Old 05-07-2017, 07:10 PM
Liked: 2
Thanks. I'm glad there's still support for them. I'll look into it soon if I decide to keep my 960. Getting kinda tight on space in my apartment, and I have been ramping up my search for a larger plasma display.
I need to see if I can rig up some sort of pulley system to haul this thing upstairs without too many casualties. If not, I may sell and buy one back when I have a larger place. Man, I have the perfect TV stand for it upstairs though...
JA Fant likes this.
lowibu is offline
post #8429 of 8429 Old Today, 04:42 AM
JA Fant's Avatar
Quoted: 268 Post(s)
Liked: 411
keep me posted- lowibu
Reply Direct View (single tube) CRT Displays
