SAMSUNG TX-P2675WH Questions - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 01-05-2005, 09:14 AM
riffjim4069's Avatar
Location: Formerly Spotsylvania VA now Dallas TX Metroplex
Lots of good info on commands you can enter while attached via the the serial cable: http://www.satelliteguys.us/showpost...0&postcount=12
riffjim4069 is offline
Old 01-05-2005, 01:05 PM
CSNHottie's Avatar
I'm a newbie who's about to get this TV and Comcast, so with the firmware and what this TV was originally supposed to do, this set should pick up the HD channels Comcast offers:
a) Basic analog cable/no Comcast box
b) Digital basic cable/no Comcast box
c) Digital basic cable w/ Comcast box (Which would make the tuner pointless for Comcast channels, correct)
d) Other, I'm retarded
Please pick one, thanks!
EDIT: Also, I think I already know the answer, but I have D* with a Hughes receiver about 1.5 years old. With this TV, if I stick with D*, I will still have to upgrade to the HD Receiver and pay the $10.99/month for the channels D* offers, correct?
CSNHottie is offline
Old 01-05-2005, 08:34 PM
Roadkyng's Avatar
I picked up this set last week. My Satellite package is due install this Friday. In the mean time I ran a splitter off the coax delivering my broadband internet and plugged it into the line running to the set (I have a CWP with everything routing from there). I get all the local channels plus a few cable only (ESPN,CNN etc). For grins I hooked up a set of rabbit ears and had the set run through a channel scan. I am able to pick up 5 of the available HD channels in the area. Not too bad for a $10 antenna. I plan on installing a good Channel Master antenna in addition to the Satellite dish. I cannot find a build date for this set but I asked the store I bought it from (Ultimate Electronics) about the firmware issue. The sales manager was aware of it and stated this set is new inventory that should not have a problem.
I do have one question - how do I find the build date?
I can do all things through Jesus Christ, who strengthens me......
Roadkyng is offline
Old 01-07-2005, 08:00 PM
johnnync's Avatar
I just picked one of these sets up this week and have the QAM issue. Does anyone have the firmware to upgrade this? I called Samsung and have been hung up on three seperate occassions. I have a cable but need the firmware...
Much appreciated is someone is willing to send it to me...
johnnync is offline
Old 01-07-2005, 10:33 PM
WideShot's Avatar
I am in need of the software for the TX-P2670WH Qam upgrade as well.
I would appreciate it if someone could send me a copy.
WideShot is offline
Old 01-07-2005, 10:48 PM
mprover's Avatar
so I had the patch done, and I get some diigtal channels, but only in standard definition (channels are like 50.x comming in in STD) . When I scan the channels in the menu, I get three options. I dont remember what they are called , b/c Im on vacation, but which do you all use? Id like to be able to get channels in actual HDTV . That would obviously be great.
mprover is offline
Old 01-08-2005, 03:18 PM
johnnync's Avatar
Has anyone run into this issue? I received the Firmware from one of the others on the forum ( I do appreciate him sending it) and performed the upgrade...everything looked good on the computer. I unplug the cable and turn the set on and my picture is just scrolling very fast. I cannont view any of the menus or the service menu.
I used my Tivo Serial cable with a null modem adapter to connect to the tv. I tried reflashing the firmware a second time and still have the same issue.
Any help is appreciated...
John
Here is the output:
D:\\samsung>sdn 1 0xdeadaaaa T_EMPRNUS1_2032.z
COM1, 115200, 8N1
T_EMPRNUS1_2032.z, 1829261 bytes
Reading file 100%
Wait Target Connection . . .
# Serial Downloader Connection Established #
# ID Confirmation #
# Send ID : 0xDEADAAAA #
# Receive ID : 0xDEADAAAA #
# Size Confirmation #
# Send Size : 0x001BE98D #
# Receive Size : 0x001BE98D #
# File Download #
# Wait some minutes #
[SERVER]Send = 100%[SERVER]Final data
File Size is 1829261, Target Address is DEADAAAA, Receive Count is 1829261
Downloaded application image size : 1829261
FLASH AREA : 0x02000000 - 0x023FFFFF(4M)
FLASH MANUFACTURER CODE : 0x00000089
FLASH DEVICE CODE : 0x00000016
MaxWriteTime : 1024 us
MaxEraseTime : 16384 ms
MaxBlock : 0x2000
WriteSize : 0x20
EraseSize : 0x20000
Erased Block Address = 0x02080000 Flash Status = 80
Erased Block Address = 0x020A0000 Flash Status = 80
Erased Block Address = 0x020C0000 Flash Status = 80
Erased Block Address = 0x020E0000 Flash Status = 80
Erased Block Address = 0x02100000 Flash Status = 80
Erased Block Address = 0x02120000 Flash Status = 80
Erased Block Address = 0x02140000 Flash Status = 80
Erased Block Address = 0x02160000 Flash Status = 80
Erased Block Address = 0x02180000 Flash Status = 80
Erased Block Address = 0x021A0000 Flash Status = 80
Erased Block Address = 0x021C0000 Flash Status = 80
Erased Block Address = 0x021E0000 Flash Status = 80
Erased Block Address = 0x02200000 Flash Status = 80
Erased Block Address = 0x02220000 Flash Status = 80
Erased Block Address = 0x02240000 Flash Status = 80
Erased Block Address = 0x02260000 Flash Status = 80
Starting To Copy Image To Flash...
Source Address = 0x09000000
Destination Address = 0x02080000
Length = 2097152
Flash Writing Proc 2097120
Verifying Flash Data OK
////(TURNING TV ON)
START
BANK
BSS
0x00000000 ~ 0x0INIT
- CS8900 ETHERNET CHIP SET INIT PROCESS START
- DTV --------------------------
- CPU CLOCK FREQUENCY : 160MHz
- RAM IMAGE BASE ADDR : 0x08300000
- BUILD IT TYPE : MAIN FLASH WITHOUT DAUGHTER BOARD
¤¼DECOMPRESS APPLICATION
SOURCE ADDRESS00
MAX SOURCE DECOMPRESSED TARGET SIZE 10329512 BYTES
Unzip start at 27, en
APP
BSS
BOARD
INIT
[ROOT 0.001] SET CODE AREA TO READ ONLY
CURRENT REGISTER 1, CONTROL REGISTER VALUE : 0x400012FF
[ROOT 0.001] ....
[ROOT 0.007] 0.011] STANDBY IN
Power info detected at 24121
Power info detectet 24126
Power ied at 24131
Power info detected at 24134
Power info detected at 24137
Power info detected at 24139
Por info detected a[ROOT 0.199] B-plus power impressed
[ROOT 0.203] DAL in[ROOT 0.496] Peripheral reset signal assertted
- PCI CON -
- Found 1'st PCI d---------------------
-Device Informations
- BUS NO : 0
- DEVICE NO : 13
- FUNCTION ID : 0x144D
- SUB SYSTEM ID : 0x0000
- SUB SYSTEM VENDOR ID : 0x0000
- CLASS E : 0x04
- SUB C------------------------------------------------------
- Allocating MEM resource @ 0x40000000 with size 0x004000000000 with size CPU -
0x28006800
- PCI CONFIGURATION DONE
============================================================ cle finished
[ROered
[ROOT 0.715] Print Task Creation Success
[ROOT 0.719] Print Task Starting Success
[ROOT 0.722] Uart Inpu.726] Uart Input MSG buffers for 4 queues
[ROOT 0.734] 8 Semaphores
[ROOT 0.737] Init TFS
[ROOT 0.742] donunted TFS 0
[ROOT 0.745] tfs_fs_check 0
[ROOT 0.748] InitSam2kLite OK !
[ROOT 0.849] Nvram Reading start
[ROOT 0.856] Service data read sRAM ID - 0xD3
================rvice data inform=============
NVRAM offset : 0x000000A8
NVRAM V_AMP value : 0x0000 : 332 bytes
s
NVRAM_VIDEO1_SERVICE_TYPE : 40 bytes
NVRAM_VIDEO2_SERVICE_TYPE : 32 bytes
NVRAM_VIDEO3_SERVI_SERVICE_TYPE : 60 bytes
NVRAM_DNIE2_SERVICE_TYPE : 80 bytes
[ROOT 0[ROOT 0.938] System NVRAM ID - 0x5A5A5A5A
[ROOT 1.070] Nvr Done
[ROOT 1.224] Errding on time to micom
[ROOT 1.228] YEAR:2083,MONTH:25,DAY:45,HOUR:45,MIN:2,SEC:41
[ROOT 1.290] Col293] Output Resolution Init Select OK !
[S2LDP_Set_Screen]<176.20>, <2096.560> : <0.0>
m_v_coef(148433124) = ms_v_size(540) * 256 / Disp_v_sizegerInit OK
[DRV_VSB_Init 1.333] Nextwave init start!
[NIM_Reset - 1.33 [DRV_VSB_Init 1.351] Digital osc control
[DRV_V done
ve uCode down start!
[DRV_VSB_Init 1.858] Nextwave uCode down finish!
[DRV_VSB_Init 1.909] NxtSetMpegMode done
[DRV_V[ROOT 2.071] sound mute off
[ROOT 2.077] Iniche
[ROOT 2.112] Init Ext Ic by Ram Cache, ic_type:0, result:0
[ROOT 2.194] Init Ext Ic by Ram Cache, ic_type:1, result:0
[ROOT 2.216] Init Ext Ic by Ram Cache, ic_type:2, result:0
[ROOT 2.230] Init Ext Ic by Ram Cache, ic_type:3, result:0
[ROOT 2.353] Init Ext Ic by Ram Cache, ic_type:4, result:0
[ROOT 2.359] Init Ex0
[ROOT 2.364] C
[API_VIDEO] @@@ API_VIDEO_SetColorTemp 3
[ROOT 2.375] Init Video Preset
[ErrPrint] Source is not external hd
[ErrPrint] [GetS3C2800GpioAck] Ack wait count = 15001
[te 0xc8
[ErrPri 15001
[ErrPrint] [S3C2800 I2C] I2C NA - Write 0xc8
[ErrPrint] [GetS3C2800GpioAck] Ack waitI2C] I2C NA -ck] Ack wait count = 150
01
[ErrPrint] [GetS3C2800Gpiot] [S3C[ROOT 2.437] Beeper start
2800 I2C] I2C NA - Write 0xcait count = 15001
[ErrPrint] [GetS3C2800GpioAck] Ack w I2C NA - Wri Ack wait count = 15001
[ErrPrint] [GerrPrint] [S3C280nt] [GetS3C2800GpioAck] Ack wait count = 15001
ait count = 1500 Write 0xc8C NA - Write 0xc8
[ErrPrint] [S3C2800 I2C] I2C NA - Write Ack wait count 2C NA - Write 0x
c8
[ErrPrint] [S3C2800 I2C] I2C NA - Writ wait count = 150A - Write 0xc8
[ErrPrint] [S3C2800 I2[ROOT 3.526] Beeper end
[ROOT 3.638] Init Clock/Time
[API_VIDEO] @@etColorTemp 3
[API_VIDEO] @@@ API_VIDEO_S[ROOT 3.683] Before OPticInit .............
[ROOT 3.687] Starting the Iniialization of : OpInitialize OK !!
<<>> horizontal stup : OpOpenDisplanager: Good OK=0000000
0
[ROOT 3.720] EW_RegisterApp: Good OK=00000000
[ROOT 3.725] EW_SpawnTask: EW_RegisterApp: Good OfTask!
[ROOT 3. 3.736] Creating Task : "Caption Input Task"
[ROOT 3.741] Creating Task : "EPG Engine Task"
[ROOT 3.745] Starting Task : "Caption Input : "EPG Engine Task"
[ROOT 3.776] X-Ray protection enabled
[ROOT 3.779] All Initiali
banner before...
mre...
[API_VIDEO] @@@ API_VIAnalog Boot up
[ROOT 4.236] UI[ROOT 5.146] UI_MAIN_ReadNvram_ChMap() END
LNA is OFF
[VDP_ConvArcToVdp] display_mode is 16:9
[S2LDP_Set_Screen]<416.9>, <1856.551> : <82.0>
m_v_coef(1484331_v_size(540)
A Channel Change time : 5711
[API_SYS_CRCCheck_FlashImage] IMAGE ADDR = 0x02080000, CRC = 0x977C0C17
[ErrPrint] [API_SYS_Gett] [API_SYS_GetAfAM2K_ERROR] S2K_Vid_SetAspectRatio, Wind
ow Size Input Parameter Outofrange error LNA is OFF
[ErrPrint] [API_SYS_GetAftLevel] aft level = 131
[ErrPrint] [API_SYS_GetAftLevel] aft level = 87
[ErrPrint] [SAM2K_ERRORe Input Parameter
m_v_coef(148433124) = ms_v_size(240) * 2A Channel Change time : 758
johnnync is offline
Old 01-09-2005, 01:29 PM
WideShot's Avatar
I just applied the firmware. It went smoothly. Did an auto-program and now I have QAM capability. Thanks RiffJim4096 for all your help.
Now my problem appears to be weak signal on the QAM cable channels. I'll have to look at my cable distribution in the house and maybe call Cox. I can only get 3 channels, and they break up badly. I get WTTG, WUSA and a basketball preview channel. Cox seems to be putting the HDTV channels in the upper end of the band, where cable attenuation is more of a problem.
One thing to note is that if you are making your own db-9 to 1/8" mini cable, wire it pin 2 to tip, pin 3 to ring and pin 5 to sleeve. Then you won't need a crossover.
Jim
WideShot is offline
Old 01-09-2005, 02:17 PM
mprover's Avatar
does anyone have the firmware to update any TXP tv. If so, Id really apreciate a PM. I had my TV flashed by a service center, but Im only able to pick up some digital channels (all the move channels, HBO, etc) in standard definiton. Im n baltmore MD using comcast.
mprover is offline
Old 01-13-2005, 04:47 AM
6Booms's Avatar
I'd also appreciate if someone with the firmware update software could send it to me. I just got a TX-P3271H. I'm in Harford County north of Baltimore MD.
6Booms is offline
Old 01-13-2005, 08:24 AM
mprover's Avatar
6b00ms, Im interested in knowing what you can get once updated. There is a place on joppa road in towson that will update the TV. They are slow with it thought. Should be covered under warrenty
mprover is offline
Old 01-18-2005, 08:14 AM
butlerca's Avatar
Hello, I bought my set back in November, I saw this fourm around that time, and there was a mention of a fix for QAM from samsung in the works.
Now i see that there is a firmware update circulating. Could someone provide me with the firmware update?
Thanks. much Obliged!
butlerca is offline
Old 01-25-2005, 12:24 PM
samjc's Avatar
John
Here is the output:
COM1, 115200, 8N1
Reading file 100%
# ID Confirmation #
# File Download #
MaxBlock : 0x2000
WriteSize : 0x20
EraseSize : 0x20000
Length = 2097152
////(TURNING TV ON)
START
BANK
BSS
SOURCE ADDRESS00
APP
BSS
BOARD
INIT
[ROOT 0.001] ....
Power ied at 24131
- PCI CON -
- BUS NO : 0
- DEVICE NO : 13
- CLASS E : 0x04
0x28006800
[ROered
s
[DRV_V done
[ROOT 2.077] Iniche
[ROOT 2.364] C
[te 0xc8
[ErrPri 15001
01
c8
0
banner before...
mre...
LNA is OFF
Hi,
Have the txp26752wh which had been previously been serviced for the QAM upgrade, successfully. TV work fine for a while, then died a couple of weeks later.
Got the new replacement today and tech guy appied Qam fix and it did the same thing you described. Did you get any resolution to this problem?
samjc is offline
Old 02-06-2005, 06:16 AM
Does anyone know how to disable that annoying power up/power down jingle?
Old 02-19-2005, 09:57 AM
WideShot's Avatar
Enter setup menu, go to VideoAdjust1 submenu, set Melody_Volume to 0.
You get to the setup menu by turning the set off, then pressing Mute 1 8 2 Power.
Exit the setup menu by pressing Power.
Be careful inside the setup menu, there are a lot of settings you don't want to change.
WideShot is offline
Old 02-19-2005, 12:23 PM
bgall's Avatar
you don't need to go into the setup menu to turn it off, it's an option in the user menu
bgall is offline
Old 02-26-2005, 11:38 AM
WideShot's Avatar
My TXP only shows about 12 hours of programming information in the program guide (over the air). It seems like a limitation with the set since friends with other receivers get more information (depending on what the station is sending).
Anybody else getting more than 12 hours of show information from the OTA guides with a Samsung TXP series set?
WideShot is offline
Old 04-21-2005, 12:59 PM
DaEnigma's Avatar
Samsung has had a problem with corrupted firmware upgrade disks.
If your unit is upgraded with the corrupted data then the eprom will need to be replaced atleast that is what samsung said on the phone. The repair facility may not want to do that though so they will just replace the main board...
I have the firmware but am not sure it is a good idea to post since it may also be corrupted I have no idea. My set also has fast scrolling lines and the picture is unusable.
I did a crc check on the disk we recieved and it was corrupt in one sector. I was able to use a data recovery tool to get the data off although it may still be corrupt I have no way to be sure...
DaEnigma is offline
Old 05-01-2005, 04:07 PM
absolutic's Avatar
thanks for invaluable thread. Now 4 months later, does anyone know if Samsung fixed the QAM issue in new sets?
Never Say Never
absolutic is offline
Old 05-03-2005, 11:56 AM
DaEnigma's Avatar
The QAM update is not applied to the TXP models in stores at this time but the models coming out later this year will have the fix applied.
So far I have had no luck on updating the firmware on my 32" TXP but I have heard the 30wide has had no problems.
DaEnigma is offline
Old 06-01-2005, 07:55 AM
coolio ice's Avatar
I don't think the new TXR series has the QAM fix implemented, since it does not appear as a feature on their website. Although the online manual still has the QAM option available, even for the TXR series.
1. Did anyone get the digital output to work? I believe it only works for digital channels. Confirm?
2. Any updates on a new firmware from Samsung?
Here is what my service tech guy said:
THERE WAS A GLITCH IN THEIR FIRMWARE UPDATE AND THEY ARE WORKING ON
IT.
Time will tell
coolio ice is offline
Old 06-12-2005, 02:50 PM
pedroluis26's Avatar
FINALLY! I should have come to this forum as soon as I realized my TXP2675WH's QAM tuner was not working. I have just sent an email to Samsung (again, ahem!) to see if I can have a technician come over to apply the QAM upgrade to my TV.
One of you talked to some guy named Alfonso Duriet, a Samsung technician. Does any of you have his email address? I want to make sure I will be ready for when I get the Samsung talk: "What are you talking about? Are you sure? This hasn't happened before." I would like to have this problem fixed so I can return the box I got to tune HD cable.
Any other advice you guys could give me in case the Samsung people try to ignore me?
Thanks to all for the enlightment on this issue.
-Pedro
pedroluis26 is offline
Old 06-14-2005, 10:00 AM
sctroy's Avatar
-Pedro
If your set is still under warranty, you'll have better luck by contacting your nearest Samsung repair shop directly and tell them you want the QAM upgrade under warranty. They can look up the service bulletin to find out the part numbers they need to order (consists of a CD and a cable). You can find warranty repair centers on Samsung's web site. This is what I did, and the repair center had the upgrade in a few days and it only took them 15 minutes to install it.
sctroy is offline
Old 06-14-2005, 10:13 AM
DaEnigma's Avatar
The QAM update once again has some problem and has been pulled from the tech site... Who knows how long it will take this time to fix the issues...
DaEnigma is offline
Old 06-17-2005, 01:01 PM
sctroy, thanks!
I called Samsung and they told me to to contact the nearest repair center, which I am about to do.
How has your TV worked since the upgrade? Any glitches? Does it affect its general performance? Just curious. Thanks for the reply.
-Pedro
Old 06-18-2005, 11:09 AM
sctroy's Avatar
sctroy, thanks!
-Pedro
It worked fine, but the set took longer than I expected to lock onto the signal. I gave the set to my dad shortly thereafter (he has a satellite dish) so I really didn't have a long time to try it out. Picture quality was excellent on cable HDTV though. The neat thing was the ability to get analog and digital stations on the same tuner - my current Sharp uses two separate tuners, so I had to switch back and forth until local Comcast began simulcasting all analog stations in digital (so I don't use the analog tuner any longer).
sctroy is offline
Old 06-27-2006, 05:23 PM
POWERFUL's Avatar
Is this firmware update gonna work for the TX-P2670WHX?
POWERFUL is offline
Old 07-23-2006, 09:03 PM
Ryn_O's Avatar
I applied the update to my tv and get the same output errors and such as a few others on this board. Any fixes or other working firmwares? I can flash again so pm me with any firmwares u might have to fix this. I think I am out of the warranty period but have attempted to contact samsung for an updated firmware. thanks guys.
Ryn_O is offline
Old 07-24-2006, 04:35 PM
justsc's Avatar
Maybe this is why Samsung pulled this firmware update from the field?
I would not advise anyone to run this update on their tvs.
justsc is offline
Old 07-24-2006, 10:48 PM
POWERFUL's Avatar
Well since for the moment it looks as if QAM is not going to be an option where I am. This means I should avoid this update. I guess what your saying is if it ain't broken don't fix it huh?
POWERFUL is offline
